Found a screw in my run flat
Old Aug 17, 2012 | 05:13 PM
Randyman2002's Avatar
Randyman2002
Default Found a screw in my run flat
Today I found a screw in the flat tread area of my Michelin run flat tire. Not being real familiar with this type of tire is there a problem with having the tire broken down and having a patch placed on the inside, then rebalanced?
I know I can just plug the hole but I think the patch is a better "fix" if I can have it done with no damage to the wheel.
Thanks in advance
Old Aug 17, 2012 | 05:21 PM
Funnone's Avatar
Funnone
Plug and patch......
Old Aug 17, 2012 | 06:10 PM
dankhts's Avatar
dankhts
Found a screw in mine last week, got it fixed....no biggie.......
Old Aug 17, 2012 | 06:25 PM
LoneStarFRC's Avatar
LoneStarFRC
From the inside. Plug patch combo.
Old Aug 17, 2012 | 06:34 PM
got-20z's Avatar
got-20z
what these guys are saying!
I've had several tires patched on the inside with no issues. Motorcycles, trucks, cars, etc. Just sucks when you have new tires and find a screw in one.
Old Aug 17, 2012 | 08:07 PM
jol's Avatar
jol
The guys are absolutely correct---plug and patch and you're ready to go. Bet you thought you were scr----
Old Aug 17, 2012 | 08:47 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The plug and patch combo's are the best. The plug portion of it seals the layers in the tread area with the patch portion is similar to a normal patch. It is important to seal the tread layers since without doing that moisture can get into that area and over time cause separation of tread.
Old Aug 17, 2012 | 08:51 PM
That's the best way to fix a runflat tire.
Old Aug 17, 2012 | 08:57 PM
superjet701k's Avatar
superjet701k
ive done both and never had any trouble drove on a plug four years in my gy f1
Old Aug 18, 2012 | 12:50 AM
El original's Avatar
El original
LOL. just had the same thing on my rear tire had it patched ....right next to 2 other patches! Greetings,Rob
Old Aug 18, 2012 | 01:47 AM
woodman300's Avatar
woodman300
St. Jude Donor '15
Default me too
that's strange. i found a screw in my driver's rear tire. it was on the shoulder of the tire and the tech said it could not be fixed. bummer too because they only have 10k on them. i got a new one pro-rated for mileage and i bought the hazard insurance so if it happens again i will get a new one free. americas tire company..
Old Aug 18, 2012 | 02:38 AM
DeeGee's Avatar
DeeGee
Originally Posted by woodman300
that's strange. i found a screw in my driver's rear tire. it was on the shoulder of the tire and the tech said it could not be fixed. ......
As the guys say, if its in the tread it can be patched up to 2 times.
That's what happened to me too. It went into the tread but into the sidewall on the inside. I've often wondered why a tire that's designed to run on its shoulder for 200 miles can't be plugged when its in the sidewall. Thats a real stiff sidewall on a runflat.
Any tire experts know the answer?
Old Aug 18, 2012 | 09:34 AM
jdsaengine's Avatar
jdsaengine
In last 2 yr I've had two screws in Goodyear runflat rear tire. Discount Tire fixed both times for free, said this tire was only allowed to be patched twice, 3rd time it had to be replaced. (which is fine I'm waiting for them to wear out anyway for new Mich.
Old Aug 18, 2012 | 09:58 AM
QCVette's Avatar
QCVette
Is there any reason why the 2 patch limit? I don't know why another patch makes a difference.
I have a GY F1 runflat that has 4 plug patches in it and is running fine, although the tread is getting worn to the point of needing replacement.
Old Aug 18, 2012 | 11:41 AM
f6john's Avatar
f6john
Same issue here, nail in the tread but according to the tire store too close to the edge to repair . I disagreed and repaired the tire myself. I bought the tires from an individual so no pro rating but for $300.00 for a pair of 295-35-18's I am still ok.
Old Aug 18, 2012 | 12:09 PM
Cirrus8's Avatar
Cirrus8
I patched my GYRF's twice with a plug from the outside. They ran perfectly with no loss of pressure until they wore out. I fixed them both with my car in the driveway and not on ramps or a jack. Simply pulled out the screws, roughed up the hole and forced in the sticky plug. returned the tire pressure to 30 psi and was good to go.
Old Aug 18, 2012 | 06:22 PM
jrose7004's Avatar
jrose7004
It can be fixed.
To Found a screw in my run flat
