Electrical connections problem ?
Old Aug 18, 2012 | 02:47 PM
killain's Avatar
killain
Oldtimer
Default Electrical connections problem ?
Can anyone tell me where I might get a new "Gas door release" clip that attachés the power lead to the switch in inside the console ? I'm installing a new rear console and someone had the console off before and broke the clip on the door release switch ? Thank you.
Old Aug 18, 2012 | 04:31 PM
LoneStarFRC's Avatar
LoneStarFRC
When you say "clip", do you mean the black 5-pin connector with two wires (1 pink and 1 orange) coming out of it?
Old Aug 18, 2012 | 07:19 PM
killain's Avatar
killain
Oldtimer
Default Gas door switch electrical connector
Yes Sir !
Old Aug 18, 2012 | 08:27 PM
LoneStarFRC
Yes Sir !
Well, good news and bad news I guess:
Good news is that appears to be a Delco PT795 part number (it has white wires, but you can release them and insert your own wires into the connector body if you want). GM part #12167129
Bad news is, it's a little spendy. Seems to run between $20 and $30 depending where you buy it.
Here's a pic of it from a vendor website, where they are installing their product by tapping into the pink/white wires coming out of it:
The AC Delco pic shows all five wires in it, but the unneeded connector pins can easily be released. I usually use a paper clip inserted from the front to push down the lock tab and pull the wire out the back.
A number of places carry it and prices vary.
You might get lucky and find someone willing to cut one off an interior wiring harness, but I wouldn't count on it though. That same little connector body is used for a lot of different functions on varous GM vehicles, so maybe a trip to the salvage yard.
$25.40 on Amazon
Old Aug 19, 2012 | 05:44 AM
killain's Avatar
killain
Oldtimer
Default Gas door connector ?
$25.40 on Amazon
I don't care so much about the $20.00, but I need it in a few days as the custome console I have had refinished is going to be shortly, Ill call Contempoary Corvette in Bristol tomarrow and I left a email for Justin at gmpartshouse.com. Mine only has th pink and white wires in itI could swap them out and be fine. When your ready to finish a job, it's these little problems that dog you to death trying to fix. Thank you for the info ! Big Help, hope I can return the favore some day.
Old Aug 19, 2012 | 08:40 AM
Good to know that some of these little parts are available, even if they are expensive.
Old Aug 19, 2012 | 09:25 AM
LoneStarFRC
Hey, I hear ya on the little details. Sometime it's those that make the difference in a quality job vs something that's just strictly functional. When it comes to anything electrical, especially things such as wiring, doing things right the first time prevents a LOT of headaches in the future and half the battle is just finding the sources for the parts you need.
Glad to help.
Old Aug 19, 2012 | 11:36 AM
killain's Avatar
killain
Oldtimer
Default Holding back the dam of water ?
Glad to help.
You said it, The whole console is or will be done, but you can't put it back in save for a $20.00 electrical clip + 25 to ship it ASAP.
To Electrical connections problem ?
