Radio Interference with LED tail lights?
Old Aug 19, 2012 | 09:00 PM
doublec4's Avatar
doublec4
Default Radio Interference with LED tail lights?
I installed some LED tail lights the other day and I noticed when I have my radio on and I hit the brakes/signal my radio cuts out. It's definitely some sort of interference going on. Anyone experience this/have a fix for it?
Thanks!
Old Aug 19, 2012 | 10:07 PM
I've run LED halo tail lights on my last two C5s and never had a problem like that. Only problem I've had was with hyperflashing - but a hyperflash harness solved that. I'd suggest you contact the vendor you bought the lights from and see what advice they can give you.
Old Aug 19, 2012 | 10:10 PM
doublec4's Avatar
doublec4
They're the ebay depo tail lights. They likely won't have any sort of an answer for me.
I bought them because I plan on doing my own mods to them. Put them on in the mean time with the acrylic tint covers over top so you can't see the chrome (the part most people don't like)
Anyways, I've found a few other threads where guys with the depo lights complained about the same thing... but couldn't find if anyone has a solution...
Old Aug 20, 2012 | 02:44 PM
doublec4's Avatar
doublec4
bump
Old Aug 21, 2012 | 07:59 PM
doublec4's Avatar
doublec4
I might try and use "ferrite cores" to solve the RFI... if anyone has experience with these let me know if you think they'll work.
Thank you
Old Nov 26, 2012 | 10:40 PM
steven623's Avatar
steven623
Default I have the same LED problem with my Depot lights
I have a 2004 C5 Z06 and when I put my brakes on, the FM station gets interference/static. Has anyone found a way to fix this problem?
Old Nov 27, 2012 | 07:50 AM
AU N EGL's Avatar
AU N EGL
check your ground wires.
Old Nov 27, 2012 | 07:56 AM
rotarydad's Avatar
rotarydad
Yup, LED's will do that. It's not just your lights. I installed overhead LED light fixtures on our boat and a few of them sound like up and down sirens through the AM radio when on. No problem with FM. Haven't found any fix yet, sorry. You might want to try a bit of dielectric grease on the contacts to see if that helps the contact.
Old Nov 27, 2012 | 08:39 AM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
The good led tails won't do that. I would get rid of those for the halos.
Old Nov 27, 2012 | 08:55 AM
doublec4's Avatar
doublec4
I was surprised to see this thread bumped.
I never did fully correct the problem, but I did read into it and it seems like this is a common problem with LEDs or the boards that power them. I believe it is conducted electromagnetic interference.
What I tried as a fix, was to use ferrite cores on the leads going into each LED tail light. If you're not familiar with ferrite cores, you've probably seen them on the power cords of many of your electronic devices like computer monitors. They are those bulging cylinders on the cord usually located close to the device itself.
You can buy ferrite cores at electronics stores. They are hollow cylinders and they snap open and shut so you can put your wires through. Ideally you want to wrap the wires through several times to reduce the EMI of the LEDs. When buying the ferrite cores, consider the thickness of the wires you're wrapping through so that you can get them to pass through several times. Unfortunately, I bought ones that were too small and I was only able to pass them through once... I noticed a small change and my radio comes in a little clearer. I'm convinced if I can pass the wires through 3 or 4 times I would have much better results. I just haven't gotten around to buying bigger cores.
Give it a try! Might help!
Old Nov 27, 2012 | 09:00 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
me too. never had that problem. didn't even have hyperflash, but when i decided to add other led lights i also installed the hyperflash harness and it worked flawlessly. assuming nothing else was touched during the install, you have a product problem that the vendor should be able to help you with.
To Radio Interference with LED tail lights?
