water weter
Old Aug 20, 2012 | 08:22 AM
black match box's Avatar
black match box
Default water weter
I was driveing in the woodward dream cruise this past weekend an I had to turn on my air to keep the car below 200 deg. besides buying a switch to turn on the fans , dose anyone know or have used the product called water wetter?. and too what results, thanks (GINO)
Old Aug 20, 2012 | 08:36 AM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Water wetter works best when only mixed with water. If your car is driven in sub zero or cold temperatures then you would have to flush your system before winter and used appropriate coolant. The product does work, but can only do so much.
Old Aug 20, 2012 | 08:51 AM
Marine One's Avatar
Marine One
When was the last time you cleaned out your radiator & AC intake? I recently did this for the first time (53,000 miles on the car), and like many others here have reported, got literally a dust pan's worth of dirt, sand, leaves and other debris out. There was even a piece of straw up there! It made about a 5-7* difference in my running temps.
Old Aug 20, 2012 | 11:03 AM
waddisme's Avatar
waddisme
These cars are designed to run on the hot side. 200* is nothing. I don't even think the dummy lights come on until 240*. At VIR last month it was 105* and mine ran 232* all day. Never got over. I am thinking the high speed fans don't come on until 235*?
The water wetter doesn't do much when mixed with 50/50 mix. I wouldn't waste the money.
Old Aug 20, 2012 | 11:45 AM
robert miller's Avatar
robert miller
I clean the trash from between the rad / air and oil cooler. about ever 3 months... Are check it at much... Robert
Old Aug 20, 2012 | 01:54 PM
black match box
I clean it about every 2nd or 3rd time I take it out. I blast it with an air hose. and spray with a garden hose. I am very **** about my corvettes. but if they run 200 or over I shouldent worry. thanks all for the info. (GINO)
To water weter
