Ticket worth fighting????
RE: after market lights - If your lights are as bright as factory lights, in bright sunshine, then you should be O.K., providing you also have the required two red reflectors (usually incorporated into the tail light lens)
Could you please point me towards the legal code that says these red reflectors have to be "showing" ie, not covered up with tint? They are still "there" just covered up until shined on.
Regardless, I doubt there's been a case where someone was pulled over because their reflectors were covered up. We are just getting nit-picky over here in a relentless urge to keep things stock or in keeping with personal preference.
Here are mine at night with the molded blackout covers:
Lastly: How often are you stopped to have your taillights checked for DOT compliance? Is that even part of an inspection (for states that have them)?
Table IV—Location of Required Equipment
"Reflex reflectors On the rear—1 red on each side of the vertical centerline, at the same height, and as far apart as practicable"
(blacked out lights don't look good on every color in my opinion.....red being one of those of colors.)
Well you'd be wrong. Tail lights blow a fuse sometimes. You're driving at night with your blacked out tail lights and that happens, you are totally dark behind. Some one slams into the rear of your vehicle and you have "willfully" covered up your reflectors! Guess who may end up on the short end of the stick in that situation?
And saying I'm wrong but not backing it up with any facts or cases does not constitute a win in my book. I said "I doubt there's been a case where someone was pulled over because their reflectors were covered up." Can you show me a case or instance that a cop pulled someone over because they didn't have reflectors in their taillights, or that were covered up? If their lights were out, THAT is why they were pulled over.
Good talkin' with ya.
S5.3.2 Except as provided in S5.3.2.1 through S5.3.2.4 and in paragraphs S5.7 and S7, each vehicle must conform to the following requirements:
(a) Each lamp and reflective device must be installed in a location where it complies with all applicable photometric requirements and visibility requirements, with all obstructions ( e.g. , mirrors, snow plows, wrecker booms, backhoes, and winches) installed on the vehicle.
Better?
Better?
The blackouts or tint are not opaque. They filter some light from getting through, but not all of it. And if the OP installs LEDs, then they shine through just fine WITH covers/tint, therefore conforming to applicable photometric and visibility requirements.
One way to get a definitive answer would be to send the lights out to Calcoast industrial testing laboratory. They offer SAE compliance testing and DOT certification
....BUT, it doesn't change the fact that your tail lights are not DOT compliant.
Her mistake was giving you a ticket for "inadequate tail lights." Next time she will be sure to give you a ticket for inadequate reflector on rear.
