cluch sticking
Old Aug 24, 2012 | 12:17 AM
stcspiderman's Avatar
stcspiderman
Default cluch sticking
I have a 01 c5 only mod is CAI, I went to drag strip other day every time after my run my clutch petal would stick to the flow, and at times I would have to put my foot under petal to pull it back up.
Its fine when I don't get on it As soon I get on it start shifting it starts sticking.. What is causing this problem?
Old Aug 24, 2012 | 12:28 AM
itzza427's Avatar
itzza427
One possible answer is dirty clutch fluid. Can cause erratic and sluggish clutch operation. Solution,, is take something like an old turkey baster and suck out the old dirty fluid,refill with fresh DOT3 brake fluid. Get back in and pump the clutch pedal a bunch. Check the reservoir and you will most likely see more black gunky looking fluid again. repeat several times till you have fairly clean results. This will improve the operation. another area would be to check the be dal return spring. Hope this helps.
Old Aug 24, 2012 | 02:54 AM
Blown 346's Avatar
Blown 346
Remove the spring behind the clutch pedal, it will stop it form sticking to the floor and you ruining your clutch.
Sounds like Hydraulics are in your near future.
Old Aug 24, 2012 | 04:24 AM
stcspiderman
I am looking redo the clutch whatever goes with it. What is good clutch kit go with I plan on doing some mods in future.
Old Aug 24, 2012 | 07:27 AM
02z06dave's Avatar
02z06dave
I had this problem a while back. After changing the fluid didn't work, I put in new master cylinder. Works perfectly now. If that is your solution as well. I recommend the tick unit. It pretty nice.
Old Aug 24, 2012 | 09:43 AM
Corvette_Ed's Avatar
Corvette_Ed
The spring serves a purpose other than just controlling pedal movement. I don't remember exactly what it is, but removing the spring isn't recommended because of it.
Old Oct 13, 2012 | 10:58 AM
Cubman's Avatar
Cubman
Replacing the clutch fluid on my 02 fixed my clutch issues. Much smoother operatng. The fluid apeared to have a little condensation in it, and some discoloration. Sucked out and refilled twice and good to go.
To cluch sticking
