Changing oil on a C5
Old Aug 24, 2012 | 01:41 PM
St.Char's Avatar
St.Char
Default Changing oil on a C5
Hey guy's, my sister drives a C5 and wants me to change her oil. What oil filter and part number do you recommend and how much oil goes in a C5, her's is an '03.
I use Mobil 1 in my C6....Thx.
Old Aug 24, 2012 | 01:49 PM
3boystoys's Avatar
3boystoys
All these "secrets" are in the Owners Manual.
Old Aug 24, 2012 | 01:53 PM
HBbadb0y's Avatar
HBbadb0y
6.5 quarts of your choice synthetic
Old Aug 24, 2012 | 02:06 PM
oh1vette's Avatar
oh1vette
Watch Advance Auto and Auto Zone - usually run a special on 5 qts oil and filter for like $32
Old Aug 24, 2012 | 02:39 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
5-30w is the manufacturer's recommended oil. as mentioned previously, your choice of synthetic. if you asked enough people here you would get virtually every brand as a favorite. if you are really **** about your car, the choice could be royal purple. for what it is worth, my personal choice is castrol edge which has out performed mobil 1 in some tests in the last year or so. look hard enough and you can make a case for virtually each and every oil out there.
Old Aug 24, 2012 | 03:34 PM
Oldvetter's Avatar
Oldvetter
Car must be level or higher in the rear. C5s have the oil drain plug in the front of the oil pan, so if you just pull front wheels up on ramps, you will leave a lot of oil in the pan. Raising the rear higher drains an additional 4 ounces of oil.
6.5 quarts is correct. There are two dipstick "systems", early years shows full at top mark (normal full mark), newer years shows full at middle mark (that's why some people overfill to 7 quarts). You are allowed to use 7.5 quarts if you go racing (track), but must drain out extra quart after you are done.
I use WIX or NAPA GOLD (same filter) oil filters, they flow and filter well.
Old Aug 24, 2012 | 06:28 PM
St.Char's Avatar
St.Char
Yeah...if she only had one
Thanks for the reply guys!
Old Aug 24, 2012 | 09:22 PM
Get some Mobil 1 5W-30 - the car takes 6.5 quarts. I use the AC Delco PF-46 filter on mine. And the procedure oldvetter mentions on raising the rear higher than the front when draining the oil is what I use.
Old Aug 25, 2012 | 08:09 AM
QCVette's Avatar
QCVette
Active Streak: 90 Days
You can download one at:
http://www.corvetteactioncenter.com/...003/index.html
Old Aug 25, 2012 | 08:17 AM
joe Villarreal's Avatar
joe Villarreal
Walmart is the cheapest place to buy synthetic oil always use mobile1 5/30 in your vette
it is recommended by the factory 6.5 qts
Old Aug 25, 2012 | 08:19 AM
baxsom's Avatar
baxsom
Originally Posted by joe Villarreal
Walmart is the cheapest place to buy synthetic oil always use DEXOS approved oil in the correct weight for your cimate in your vette
fixed for you.
Old Aug 25, 2012 | 08:37 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
pf44 oil filter
http://www.corvettedreams.com/oil.htm
http://www.youtube.com/watch?v=jHCqJQ8K4g0
Thanks,Matt
Old Aug 25, 2012 | 10:01 AM
CatCam's Avatar
CatCam
pics of sister? you know the CF rules on this -- perm-a-ban.....
Old Aug 25, 2012 | 10:18 AM
Corvette_Ed's Avatar
Corvette_Ed
Originally Posted by baxsom
fixed for you.
I use 10/30 because the temp never drops below 20 degrees F where I live, which is what the owner's manual suggests as an acceptable alternative for hotter climates.
To Changing oil on a C5
