Tire Question
Old Aug 25, 2012 | 12:44 PM
elopez1986's Avatar
elopez1986
Default Tire Question
Hello,
I have a 2002 Corvette and had a tire question.
I have Z06 rims (10.5'' rear tires) with the stock 275/40/18 rear tires.
I have also lowered my car with the factory bolts!
So my situation was that I tried to install Nittos 305's and they seemed to be too big (too tall since it waas lowered)
So my question is if I put the stock Z06 rear tire size with these rims will the have enough clearance?? (295's)
Thank you !
Old Aug 25, 2012 | 12:50 PM
NukeC5's Avatar
NukeC5
Originally Posted by elopez1986
Hello,
Thank you !
What was the number following 305? You must go down to 30 or 35 from 40 to run wider tires and keep the height down.
Old Aug 25, 2012 | 02:53 PM
elopez1986's Avatar
elopez1986
What if i lowered the car with the factory bolts?
Cause my issue was that the 305s were too tall since i lowered them
Old Aug 25, 2012 | 04:22 PM
NukeC5's Avatar
NukeC5
Thats what we are saying. 305 will be the same height if you go down on the second number. Its only wider. If you had 305/40 it would be too tall. 305/35 would fit fine. Most of us have lowered vettes and squeeze wid tires on.
To Tire Question
