[Z06] c5z or keep my c6z?
Old Aug 27, 2012 | 12:31 PM
02z06dave's Avatar
02z06dave
I think you should definitely go for the c5z. In fact, ill trade you mine.
Old Aug 27, 2012 | 12:51 PM
getkong's Avatar
getkong
Originally Posted by Grimlock
EBCM module fix on a C5Z is a $150 fix. Why would that stop you?!?
even less if you do it yourself. i did the whole thing in two hours, and most of that time was spent prying the thing open.
Old Aug 27, 2012 | 03:12 PM
zeevette's Avatar
zeevette
If the only problem with the LS7 is the valves, wouldn't everybody that owned one have Trickflow heads installed, with a FAST intake? There's got to be more than just valve issues? BTW, pretty sure you can use LS1-6 heads on LS7 blocks.
Old Aug 27, 2012 | 03:40 PM
ggroller's Avatar
ggroller
Just curious. Why would you want to do that?
Old Aug 27, 2012 | 06:11 PM
zeevette's Avatar
zeevette
For expediency, and lower cost would be my only reasons. I believe aftermarket valves for factory, and aftermarket heads can be more reliable. I'm not a LS7 owner, nor do I plan to be.
Old Aug 27, 2012 | 08:18 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
No.. because 99% of the LS7's running around stay stock.. 99% of the people DONT like to mod their cars to that extent. Also, the LS7 exhaust valve dropping issue is about as common or less than the LS6 valve spring issue. You guys are totally blowing this out of proportion.
Old Aug 27, 2012 | 09:03 PM
vant's Avatar
vant
That may or may not be true regarding failure rates. Nonetheless, the cost of replacement is what grabbed my attention. Bottom line, the LS7 costs 3x as much as the LS6. That's nothing to sneeze at.
Old Aug 27, 2012 | 10:17 PM
LS9Drew's Avatar
LS9Drew
Keep your C6Z, get heads if your that worried only like 2 have failed with heads and one of those was done by a subpar installer the other was a race car
http://forums.corvetteforum.com/1581453441-post129.html
http://forums.corvetteforum.com/1581451671-post102.html
Old Aug 30, 2012 | 11:47 PM
HYPRACTV's Avatar
HYPRACTV
Originally Posted by danziger
I luv my C5Z, but think you're crazy to swap in your situation.
Ditto. I have owned both.
I'm currently in a C5Z and enjoying every minute only b/c that was all my toy budget would allow. Given the opportunity I would jump to a C6Z in a heartbeat!
Old Aug 31, 2012 | 10:18 AM
AU N EGL's Avatar
AU N EGL
Lets Repeat that.
Old Aug 31, 2012 | 12:24 PM
Black 02's Avatar
Black 02
Keep the C6Z and replace the ls7 with a $400 junk yard 4.8 when it blows
Old Aug 31, 2012 | 06:10 PM
ctusser's Avatar
ctusser
Then sell it right away as a completely stock car
Old Aug 31, 2012 | 06:58 PM
  #33
zeevette's Avatar
zeevette
Hey, I've got no dog in this hunt; just saying what's possible. In a related issue, if I had traded up to a C6Z; it'd end up modded. Long run, it's alot more $$$ to upgrade a LS7, even if the result is very effective.
Old Sep 8, 2012 | 05:30 PM
  #34
msnbound's Avatar
msnbound
Just get an aftermarket warranty like I did throGh my credit union...... Covers EVERTHING minus maintenance stuff.... It's like $2300 for 7 years, 100k miles..... Cheap insurance imho
Old Sep 14, 2012 | 12:09 AM
  #35
SlingindirtM95's Avatar
SlingindirtM95
Keep the c6z. Ride quality is hands down night and day better
Old Sep 16, 2012 | 06:49 PM
  #36
MTPZ06's Avatar
MTPZ06
[QUOTE=02sscamaro;1581662570]yes this sounds crazy but hear me out. i bought a 07 z 7months ago all stock 14,000 miles. blown motors are popping up left and right with these cars. stock or modded. i like too mod my cars but this one i cant just dont have that type of cash too throw around. $15,000 4 a motor no thanks. the dealer i bought this z from has a 04 z 9,000 miles 4 31,000 all stock. is it worth it too by the 04 and do cam heads long tubes? the 07 z makes alot of power but most of it in the upper rpm range i would like something more streetable if that makes any sense? not sure what too do?[/QUOTE
For the money you spend on LT's and a cam for the C5Z, you could just pull the heads and send them off to WCCH for some upgrades. Keep what you got...and this is coming from someone who's owned both a C5Z and currently a C6Z.
Old Sep 20, 2012 | 02:04 PM
  #37
JeremyGSU's Avatar
JeremyGSU
However, there is a major difference here in that the LS6 has a known fix for the issue and the LS7 doesn't. Modded or stock people seem to pop them and there still isn't a clue as to why it happens or what the fix is. And while I agree there are a lot out there that aren't having issues blown motor threads on the C6 Z keep popping up. At least from what I've seen.
To c5z or keep my c6z?
Old Sep 20, 2012 | 10:44 PM
  #38
RC000E's Avatar
RC000E
I have a nice, built, plump LS7 on an engine stand waiting for just the right blown Z to come along at just the right price....
Aftermarket heads on mine...so no machining flaws to wreck my stuff either...
Old Sep 21, 2012 | 03:05 PM
  #39
Coach62's Avatar
Coach62
St. Jude Donor '12
With all due respect, there is a bloody ton of incorrect info on here.
The c6 z valve failure is not very rare as stated, do your homework. Tons of posts here and elsewhere about it.
Replace the c6 valve springs? WTH would that accomplish, not even remotely the problem. The problem is either the valve, the guides, or the rockers or some combination of that.
c5z spring failures are NOT common, especially in later years. If that bothers you then spend a few hundred $$ and replace them. Springs are very cheap so who cares.
I will probably own a C6Z some day and the first thing I'll do is replace the heads. IMHO based on what we currently know (and what we don't know) it's the only sure way.
Old Sep 21, 2012 | 07:58 PM
  #40
VCUFAN's Avatar
VCUFAN
Keep the C6Z.
