2000 ABS Question
Old Aug 28, 2012 | 09:55 AM
John BX NY's Avatar
John BX NY
Default 2000 ABS Question
The EBCM for my 2000 Corvette p/n 19244084 is not available from GM or anywhere else as near as I can tell.
Is there anyplace that can repair them or is used or ebay the only choice ? Thanks in advance..
Old Aug 28, 2012 | 10:06 AM
Corvette_Ed's Avatar
Corvette_Ed
They can't be repaired and there are no replacement parts available. You'll have to start searching eBay and your local/online junk yards, and hope you can find one reasonably priced. Get ready for some sticker shock. You might check with Vettenuts and see if Marc has one available.
Old Aug 28, 2012 | 05:22 PM
Phanni's Avatar
Phanni
IThe only resource forthe 1997-2000 EBCM is through someone that has one in hand. As you know GM does not stock them, and they are unrepairable.
If you have 'active handling you'll need a very expensive 'V' version of the EBCM, if you don't have active handling the less expensive 'M' model will work.
I know someone that has both on their shelf. If you need one he'd be willing to talk 'terms'
PM me if you want more info.
Old Aug 29, 2012 | 12:45 AM
It's a shame that this particular part is not available through the GM supply system - hope you can find a used one at a decent price.
To 2000 ABS Question
