A/c button flashes ?
Old Sep 6, 2012 | 04:18 PM
1ST-C5's Avatar
1ST-C5
Default A/c button flashes ?
and it doesn't blow cold, whassup wid dat?
Old Sep 6, 2012 | 04:22 PM
andym1999's Avatar
andym1999
mine did it in Yellowstone the other morning... it was 34 degrees. That may have something to do with it. What do i know though
Old Sep 6, 2012 | 04:37 PM
1ST-C5's Avatar
1ST-C5
It's 85 degrees here. Black car. I need the a/c working bad.
Old Sep 6, 2012 | 04:45 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
prob low freon. Mine does same thing and when i checked it with a set of manifold gauges, its zero on both high and low.
Old Sep 6, 2012 | 04:52 PM
robert miller's Avatar
robert miller
you got it also to the OP when it get to low it will totally cut off to keep from you from replacing the comp. Go by auto zone and get that new can that is out now that any one can chg the system with.. Robert
Old Sep 6, 2012 | 05:02 PM
2KFRC5's Avatar
2KFRC5
Bad Outside Temp Sensor #10248401 $12.70+. Reads 34°, thus not allowing the A/C to come on.
Same thing happened to mine with flashing light.
Any DTC's?
http://www.corvetteweb.com/2000dtc.html
Old Sep 6, 2012 | 05:15 PM
Randyman2002's Avatar
Randyman2002
Low freon I believe.
Old Sep 6, 2012 | 05:41 PM
TorchRedRocket's Avatar
TorchRedRocket
Low freon.
Old Sep 6, 2012 | 06:31 PM
Mickeyrx70's Avatar
Mickeyrx70
for andym1999 ;
The AC won't work at temps below about 35*-40* F. The AC light flashes if pressed when the air conditioning is not available. Makes sense to check the outside temp sensor & if it's OK, check the freon charge.
Old Sep 6, 2012 | 08:35 PM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Isn't it still summer all over America? Low freon made mine flash.
If it is 40° somewhere I feel for you. We're still low 90's
Old Sep 6, 2012 | 10:09 PM
jlbsam's Avatar
jlbsam
i second the other folks, low freon and maybe the compressor is bad
Old Sep 6, 2012 | 10:43 PM
dmarkshark's Avatar
dmarkshark
First thing, does your temp read the correct outside temp after you have driven it a bit? If so, then , as already mentioned, you have and AC issue, low freon, leaking parts, etc, that will need to be check out. Yeh , you can put freon in it, but for how long? I would suggest getting the system checked out and fixed correctly.
Old Sep 6, 2012 | 10:44 PM
jrose7004's Avatar
jrose7004
Low freon.
Old Sep 7, 2012 | 12:10 AM
Rexde1's Avatar
Rexde1
If you have the AC on and the compressor isnt turning its porbably low on freon.
Old Sep 7, 2012 | 12:44 AM
Quik Z06's Avatar
0Quik Z06
Former Vendor
On my brothers Sierra the light was flashing and no cold air. Actually his wasn't blowing very much air at all. Ended up being a resistor for the blower motor and it works great now.
Old Sep 7, 2012 | 01:52 AM
DeeGee's Avatar
DeeGee
The flashing light is telling you the AC is not working so work through logically.
If the OAT is warmer than 35 degrees that means it should be working. An auto inhibit prevents it from operating at low temperatures. A bad OAT sensor will cause a similar symptom as the car thinks it cold but that will set a code.
Worth checking the codes next as an HVAC fault could cause it. Post any codes and we can find a procedure from the manual for you.
At that stage, if the codes are clear, I'd have the freon topped off because as the guys say, that will also cause the flashing light.
99-HVAC - Heater, Ventilation, Air Conditioning
• B0332 Outside Air Temp Sensor Short to GND
• B0333 Outside Air Temp Sensor Open
• B0337 Inside Air Temp Sensor Short to GND
• B0338 Inside Air Temp Sensor Open
• B0348 Sunload Temperature Sensor Open
• B0361 Left Actuator Feedback Short to GND
• B0363 Left Actuator Feedback Open
• B0365 Right Actuator Feedback Short to GND
• B0367 Right Actuator Feedback Open
• B0441 Left Actuator Out of Range
• B0446 Right Actuator Out of Range
• B1016 Loss of Communications with PCM
• U1064 Loss of Communications with BCM
• U1096 Loss of Communications with IPC
• U1255 Serial Data Line Malfunction
Old Sep 7, 2012 | 09:24 AM
Cee5Go's Avatar
Cee5Go
Mine was low on freon
To A/c button flashes ?
Old Sep 7, 2012 | 09:52 AM
1ST-C5's Avatar
1ST-C5
Default Thanks for all the directions.
My local a/c wrench plugged into a diognostic. He said i have only have half of the required pressure on the low side. My out temp sensor is reading well below the real temp.
Old Sep 7, 2012 | 10:48 AM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Subscribing...
Just be glad your car did not read this when you get in.
My daily driver said this yesterday when I got in...
Old Sep 7, 2012 | 12:12 PM
DeeGee's Avatar
DeeGee
Originally Posted by Toque
Subscribing...
I remember those days in San Antonio. My record in Vegas was 126 degrees but I never got the picture. This was the best I did. Glad my AC worked that day
Nowadays it's more at the 32F end of the scale which is why I know the answer to the OPs question.
