Cooling problem
Old Sep 11, 2012 | 12:47 AM
Rwvette2's Avatar
Rwvette2
Default Cooling problem
I just started having some cooling issues yesterday, I was driving on the highway and the check gauges light came on. It said that the coolant was over temp. Turning off the A/C and turning the heater did not really do much. Got back on and drove right home with it. This morning I drove it to work no issues... drove it to lunch, let it ideal for a while never broke two hundred degrees(this is in TX with 98 degree weather today) sat there for 10 mins never had an issue. Then tonight I was driving home and on the highway it started to rise(I did get on it a little on the way out of the parking lot to test it out some) half way home the same lights came on saying coolant was over temp then right when I was pulling in it was showing 270 and reduced power as I was gliding into the garage. I had some coolant come out the top of the cap, nothing else. I have never flushed my coolant system and am thinking this could be an issue, but I am really thinking this could be the thermostat since the car is an 04 and I don't think this has ever been changed... Any thoughts on this? Where should I start to have a dealership look? I live in an apartment so I really dont have anyway to work on it so I am looking to do this as cheap as I can. Thanks for any advice
2004 stock Corvette(not a Z)
Old Sep 11, 2012 | 07:26 AM
runner140*'s Avatar
runner140*
Mine did that when I threw the serpentine belt....in two minutes.
Open the hood and do a full inspection. Refill with a mixture of 50/50% distilled water and DexCool.
Make sure the belt is there. Make sure there is nothing stuck up in front of the radiator. Make sure there are no collasped hoses. You could have a stuck t-stat....take it out and check it. Make sure the radiator cap is still good. After you have filled the system with coolant, make sure the water pump is circulating the coolant.
PM me with any questions.
Old Sep 11, 2012 | 08:45 AM
RespondsWithGif's Avatar
RespondsWithGif
Could possibly be air bubbles in there too. Mine will do that sometimes and if I give it a quick rev to 3-4k and it will drop my temps within the next 30 seconds.
Old Sep 11, 2012 | 09:16 AM
knewblewkorvette's Avatar
knewblewkorvette
Old Sep 11, 2012 | 09:56 AM
The_Moo's Avatar
The_Moo
Is the coolant tank full?
It may be your thermostat sticking.
Old Sep 11, 2012 | 10:51 AM
Road Runner's Avatar
Road Runner
St. Jude Contributor '03 & '04
I had very similar problems for several days until I lost the entire cooling system. The surge tank had a crack in it and wouldn't hold pressure. Check the tank.
rr
Old Sep 11, 2012 | 11:08 AM
_r2h's Avatar
_r2h
Could be any number of problems.
Not enough coolant.
Air in the system.
Not holding pressure.
Pump is gone.
Thermostat stuck.
Clean out the radiator fins.
Get to crackin!
Old Sep 11, 2012 | 08:01 PM
angman5's Avatar
angman5
This may sound crazy but I did a HID kit install for a friend of mine they worked fine but the resister that came with the kit was a real cheap part and the instructions were not clear. I put it in line with the headlight power feed and when he drove it the temp gage was peging out hot but you could tell the car was not hot lay your hands on the overflow tank and it was warm.
Pulled the resistor off and the problem went away after disconecting the battery fro a minute and then hooking it back up. This was a log story to tell you if you did a HID upgrade you might have a problem:
Old Sep 11, 2012 | 08:51 PM
Rwvette2's Avatar
Rwvette2
Thanks but no HID upgrade... and car is running hot due to it reducing power last night(I think)
Old Sep 11, 2012 | 09:21 PM
Rwvette2's Avatar
Rwvette2
Does anyone have a pic as to where the Tstat is? I think I know but I want to make sure... Thanks guys!
Old Sep 11, 2012 | 10:03 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Not enough coolant.
Air in the system.
Pump is gone.
Thermostat stuck.
Get to crackin!
If you have a 2004 and the coolant has never been changed, it might be a good time to have it flushed and have the system checked.
The thermostat is pretty easy to check/swap, however you will need to drain the coolant first. 2004 is easy as it pops right out.
Old Sep 11, 2012 | 10:35 PM
Not enough coolant.
Air in the system.
Pump is gone.
Thermostat stuck.
Get to crackin!
And yes, you sure do need to change the coolant regardless of what you find. 5 years or 100K miles, whichever comes first, is the coolant change recommendation.
Old Sep 11, 2012 | 10:42 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
"coolant was over temp then right when I was pulling in it was showing 270"
Originally Posted by knewblewkorvette
270* is a killer. Good advice has been given, but be sure to check radiator, make sure no walmart plastic bag is blocking fins. Probably is time for a coolant change too....
To Cooling problem
