window rattle
Old Sep 12, 2012 | 12:04 AM
7t7's Avatar
7t7
8th Gear
Default window rattle
While searching answers to repair window rattle on my 1999 I found many good ideas, but once I removed the door panel and speaker I found the 3/8" diameter
1" long rubber tubing that had shifted up out of the bushing at the bottom of the front rail that the window rides. I pushed the tubing into the bushing and then used a 3/8" nut driver to push it all the through the bushing. No more rattle. I hope this helps anyone having this problem.
Old Sep 12, 2012 | 12:16 AM
Good info - thanks.
Old Sep 12, 2012 | 01:01 PM
Vetterthanyou2's Avatar
Vetterthanyou2
Thanks for that. Ive found my drivers side will rattle if rolled down ALL THE WAY. If I leave it up a few inches, it stops. Interesting.
To window rattle
