[Z06] HELP!! CANNOT get shifter knob retainer out!!!
Old Jun 2, 2002 | 12:02 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default HELP!! CANNOT get shifter **** retainer out!!!
It WILL NOT come out.
I have just about destroyed the top of the retainer by biteing onto it with visegrips and trying to pry it out.
It just WILL NOT come out.
What do I do now boys and girls??
I've got this fancy smancy MOJo or MOmo shifter **** and can't get it on there because of this.
Is this the secret "vehicular retainer" that is holding the whole car together?
This darn thing is tighter than Ft.Knox.
Can I drill it somehow to remove the tension?
Help me out guys. The more it won't come out, the more I want it out.
This is affecting my sanity.
[Modified by VetNutJim, 10:03 PM 6/1/2002]
Old Jun 2, 2002 | 12:10 AM
RPO_Z06's Avatar
RPO_Z06
Cruise-In III Veteran
St. Jude Contributor
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (VetNutJim)
Try twisting the **** while you pull on the wedge..
Your doing it as right as I know how to, some of them are just a BIATCH.. :smash:
Old Jun 2, 2002 | 12:44 AM
Fast Mover's Avatar
Fast Mover
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (RPO_Z06)
I remember having that same nightmare. My retainer broke off completely. I had to drill a hole, screw into it and yank. Sucky experience, Good luck!
Old Jun 2, 2002 | 02:50 AM
antigrav's Avatar
antigrav
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (BRADS C5)
The retainer is 'T' shaped, if you can get the edge of a flathead screwdriver or similar implement underneath the edge, you should be able to pry it out.
-ag
Old Jun 2, 2002 | 07:37 AM
hcvone's Avatar
hcvone
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (antigrav)
Mini Vise Grips and a small hammer worked for me, some are a real pain to get out
Old Jun 2, 2002 | 08:51 AM
rcr162's Avatar
rcr162
Try to get the visegrips locked onto the top of the retainer, if there's still enough of it left. Then use a side to side rocking motion while pulling straight upward at the same time. This requires having the shifter in gear and using two hands. With patience you should be able to gradually get the retainer to loosen and come out.
Old Jun 2, 2002 | 12:08 PM
Rapid's Avatar
Rapid
Have removed two *****. A flatblade screwdriver on each side. Pried up. Pin came out easily both times. :D
Old Jun 2, 2002 | 02:02 PM
CANTEX's Avatar
CANTEX
I put a flat head screwdriver under the left side of the pin and tapped the screw driver handle downward with my hand and the pin came up pretty easy. I also shot a little WD40 in there first. With the screw driver under the pin the handle should be running over your right leg, start tapping down on the screwdriver handle.
[Modified by CANTEX, 6:04 PM 6/2/2002]
Old Jun 2, 2002 | 09:58 PM
JeffMc's Avatar
JeffMc
Ended up drilling mine out also.
- JeffMc
Old Jun 2, 2002 | 11:50 PM
Terry Humiston's Avatar
Terry Humiston
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (JeffMc)
I drilled the one on my 99 last week. Drilled and tapped it to 10/32. Make sure you go deep enough, at least a 3/8"
Old Jun 2, 2002 | 11:54 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
UPDATE:
This one WOULD NOT come out amigos.
The screwdrivers broke the ears off the retainer on the left and right side with no results.
The visegrips came off (several times) after being clamped TIGHTLY until the top of the retainer was pretty chewed up.
I had to drill into it using progressively larger drill bits until it finally gave up and came loose.
I think I got up to 11/32 before the darn thing gave up.
What a PITA.
Thanks for all the input boys and girls. It encouraged me to keep trying.
The red MoMo Combat Shift **** is happily installed now on my '02 Zbus.
I did save the original shifter **** without a scratch on it. (I was VERY careful). The retainer is toast, however.
You guys are just the BEST!!!
Old Jun 3, 2002 | 12:31 AM
pitrider's Avatar
pitrider
I had to drill mine out..try on the sides of the broken retainer..ruined shift ****,what a bitch :mad
Old Jun 3, 2002 | 06:17 PM
turbolou's Avatar
turbolou
I had a simular experience, Made a slide hammer affair useing a pair of vise grips attached to it. Makiing sure when I reinstalled it not to make it so tight. :seeya
Old Jun 27, 2002 | 09:03 AM
C5 StockSwap's Avatar
C5 StockSwap
Cruise-In V Veteran
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (turbolou)
Soaked mine with PB Penetrating Catalyst to loosen it up some, then vice grips with the screwdriver as a lever against a block of metal. It slowly came up...I had almost given up, but I knew it could be done thanks to the forum.
Old Jun 27, 2002 | 10:32 AM
levettegrl's Avatar
levettegrl
Cruise-In IV Veteran
hey Jim that's the same shift **** I just ordered!
got any pics?
and I do believe CONGRATULATIONS is in order on your successful MOD install! haha!
-Leslie:)
Old Jun 27, 2002 | 12:28 PM
gmblack3's Avatar
gmblack3
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (levettegrl)
I used the 2 flat-tip screwdriver method and had no problems. It came right out. I installed the MGW silver ****. Very nice and a great Price $45
http://www.mgwltd.com/corvette_pistol_grip_knob.html
Old Jun 27, 2002 | 10:29 PM
AFVETTE's Avatar
AFVETTE
I just installed my Hurst today and sprayed some WD40 down around the pin and let it penetrate while I took the console apart. I don't know if it was that , a new angle or just plain old dumb luck but on the first pull it popped out.
Glad you finally got it out - what a major PITA.
Tom
USAF Retired
[Modified by AFVETTE, 8:31 PM 6/27/2002]
To HELP!! CANNOT get shifter knob retainer out!!!
Old Jun 27, 2002 | 11:32 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: HELP!! CANNOT get shifter **** retainer out!!! (AFVETTE)
Thanks AFVETTE. I think some are just tighter than others.....
Aluminum Bezels hmmmm Hey how hard is it to put THOSE on????
I LIKE'EM!!!
Old Jun 28, 2002 | 11:33 AM
Mike Siska's Avatar
Mike Siska
Put a small pair of vise grips on the retainer and put the biggest pry bar I have into the opening of the vg jaws. Just pried up! Came right out. Used the biggest Snap-On pry bar (about 1.5 fett long)
Old Jun 28, 2002 | 12:39 PM
jeffsherman's Avatar
jeffsherman
I ended up using a dremel with a cutting wheel and destroyed the original shift **** to get the beast out. I think the assembly line person used a mallet on mine.
