dead battery
Sep 13, 2012 | 03:21 PM
dead battery
I have a 2000 A4 conv. Just returned from vacation and battery is completely dead. I can't get it to charge or jump. Can it be removed without losing computer? I started to unscrew the positive cable and it made some noises near the front wheel well so I retightened the cable.
I was going to take th battery out and have it tested. Ideas on how to proceed?
Sep 13, 2012 | 03:23 PM
St. Jude Donor '09-'10, '14
remove the negative cable first. Then the positive. Yes there is no other way to replace it.
You will have to reset everything like radio etc, but the computer will be fine.
When you replace it, replace the positive first, then the negative.
Sep 13, 2012 | 03:48 PM
dead battery
Thank you Sarge and thanks for your service.
Sep 13, 2012 | 03:50 PM
Quote:
Originally Posted by
RetiredSFC 97
Good luck with the swap.
Sep 13, 2012 | 04:14 PM
Then get a battery maintainer, and use it when your C5 sits for more than 3 days. These C5's use a lot of battery.
Sep 13, 2012 | 04:19 PM
Oldvetter
I agree.
Sep 13, 2012 | 04:20 PM
RetiredSFC 97
Correct. I just swapped mine a week ago. No problem.
Sep 24, 2012 | 04:09 PM
Check for a draw with a test light between the terminal and cable. Mine was a glove comp light.
Sep 24, 2012 | 05:06 PM
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Take a look here.
http://forums.corvetteforum.com/1567522286-post590.html
Bill Curley has lots of great info on testing electrical issues on these things. I think that's his hobby is tearing the electrical systems down and rebuilding them, (every night after dinner).
