Outside winter storage tips
Old Sep 19, 2012 | 02:29 PM
GTJim's Avatar
GTJim
Default Outside winter storage tips
Guys, my Vette is kept outside and not in a garage. I'm have a few questions about outside storage in the winter. Just did a fresh wax job on it so that's taken care of. It was just recently service with all fluids checked and replaced if needed. I'll be disconnecting the battery and covering the car as well.
My one concern is flat spots in the tires. I might try inflating them to the max psi to compensate for any air loss through the winter months. My preference would be to take them off and put the car on jack stands. I could also get some cheap wheels/tires and put them on. The thought of using donut spares also came to mind.
Any advice on what to do? Do any donut spares from other GM vehicles fit the Vette? Am I missing any thing other than what I mentioned above?
Thanks in advance!
Jim
Old Sep 19, 2012 | 02:52 PM
STALION's Avatar
STALION
From: ALL governments are legalized mobsters, so doesn't matter where I live :(
Hi Jim,
The days of propping the car up and removing the wheels should be behind us. Todays tire tech makes for a stronger tire, not to mention the car realistically sits between 4 to 6 months...not that long at all. If your still concerned you can add a little extra air and also place square styrofoam pieces underneath the wheels.
When I use to store my mustang vert I would place a plastic tarp on the ground, drive my car on it, put on my soft cover over the car, take another large tarp place that over the soft cover then tie the top tarp over the bottom tarp like an anchilada, lol.
Old Sep 19, 2012 | 05:00 PM
DBLTRGR's Avatar
DBLTRGR
Originally Posted by STALION
Hi Jim,
This sounds like a great way to protect your car in a windy area. Normally the wind gets under the car cover and blows it off. If you try tying it down you risk having rope marks on your paint. But the twin tarp idea would eliminate that because the wind can't get underneath.
Old Sep 19, 2012 | 05:05 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
where you live will make a huge difference and we don't know that.
But I do like the tarp idea used over a good quality car cover. If you use just a cover they come with straps that go under the car to prevnt it from being windblown but they are not fool proof though.
Old Sep 19, 2012 | 07:34 PM
GTJim's Avatar
GTJim
Hi Jim,
They actually make car bags which are much like you describe but I've heard horror stories about moisture getting trapped in them and causing rust and mold among other things. My car is covered so that's not an issue. The issue is the flat spotting of the tires which will still happen even with todays tires.
Old Sep 19, 2012 | 10:55 PM
If you disconnect the battery and live in an area that the temps get pretty cold, I would remove the battery from the car and store it inside your house.
Old Sep 19, 2012 | 11:12 PM
GTJim's Avatar
GTJim
I'm in the North East so that's prob not a bad idea.
Old Sep 19, 2012 | 11:52 PM
duramaxsky's Avatar
duramaxsky
I am glad I don't store them outside. I have covers for them inside. A battery tender is a good idea inside or out.
Old Sep 20, 2012 | 12:47 AM
itzza427's Avatar
itzza427
Just to save reprograming headaches in the spring,,,I would leave the battery in and connected.I would then add a quality battery maintainer such as the C-tech,, and then all settings are kept and you have a fully charged battery when you are ready to go!!
Old Sep 20, 2012 | 01:15 AM
mighty mousd's Avatar
mighty mousd
Which will go away pretty quickly when you drive it.
To Outside winter storage tips
