[Z06] Engine fluid changes
Old Sep 21, 2012 | 03:52 PM
Mayor's Avatar
Mayor
Default Engine fluid changes
Having recently purchased a 2001 Z-06, I was wondering about changing the engine fluids, ie. radiator, differential, oil, etc. prior to storing for the winter, or is it better to do after I bring it out in the spring ? I live in Michigan and will not be driving it in the winter months. Thank you
Mayor
Old Sep 21, 2012 | 05:55 PM
MY03C5Z's Avatar
MY03C5Z
Definitely better to change them before letting it sit for the winter, especially with engine oil. Used engine oil contains acids that are bad for bearings especially when left to sit for long periods.
Old Sep 21, 2012 | 08:03 PM
VCUFAN's Avatar
VCUFAN
Pretty easy job, would do it before you store it.
Old Sep 22, 2012 | 06:13 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
YEP!
Old Sep 24, 2012 | 06:45 AM
LoneStarFRC's Avatar
LoneStarFRC
Originally Posted by Bills Z06
YEP!
+4
Don't forget the fuel tank too. I would either use Sta-Bil (follow directions) or at least use a bottle of Techron. Either way, make sure you fill completely up immediately before storage.
Old Sep 24, 2012 | 10:27 AM
ttz's Avatar
ttz
Originally Posted by LoneStarFRC
+4
Really? I was always under ther impression you would want as little fuel in there as possible since it still gets old (even though it has a stabilizer) So full tank is better?
Old Sep 24, 2012 | 02:25 PM
LoneStarFRC
Use of Sta-Bil, etc, is designed to specifically combat what you are speaking of plus combat water. Having a full tank (tanks in our case) minimizes the amount of air in the tank, and thus the possible presence of water due to condensation.
No air, no condensation - or at least very, very minimal amounts.
HTH
To Engine fluid changes
