ac pulleys
Old Oct 7, 2012 | 04:25 AM
red03vette's Avatar
red03vette
Default ac pulleys
i am replacing the ac pulleys after changing the belts and it not fixing the squeak. did some searching on the forums and came up with a torque spec of 37 ft-lbs. does this sound right? i don't want to under or over tighten this fastener. thanks
Old Oct 7, 2012 | 10:48 AM
dblerman's Avatar
dblerman
37ft lbs is correct
Old Oct 7, 2012 | 12:45 PM
red03vette's Avatar
red03vette
Thank you sir!
Old Oct 7, 2012 | 01:13 PM
NukeC5's Avatar
NukeC5
What belts did you go with? I changed belts first thing when having belt chirps as well. After replacing both idlers and tensioners it ended up being the belts still because of the flaw in the design of the pulleys. The ribs are not deep enough, or the ribs are too long on the belts. Anyways, used Goodyear gatorback belts and the problem went away for good.
If you keep chasing squeaks, try gatorback belts. They work great.
Old Oct 7, 2012 | 02:09 PM
red03vette's Avatar
red03vette
That's a good question, I think they are gates. Purchased them from Napa. It's definitely the ac system, removed the main belt squeak was still there, removed the ac belt and squeak was gone. I did ask the partsman at Napa for the gatorbacks and his reply was "we can't get them". So I just went with the gates. After I installed the new belts the squeak was gone... For a little while. Couple days later out for a drive and pulled a couple shifts up around 5000rpm's and the squeak came back. So my thinking is the bearings in the pulleys are dried out and don't like the extra load placed on them from higher rpm's. What do you think? Once I change the pulleys I will let you know how it turns out.
Old Oct 7, 2012 | 02:49 PM
NukeC5's Avatar
NukeC5
Give it a try, but that's exactly what mine did. New belts fixed if for awhile, then it came back. after replacing everything the squeak came back again. It was the new belts still squeaking. If that happens, order gatorbacks online and you will be good to go.
Old Oct 7, 2012 | 03:19 PM
red03vette's Avatar
red03vette
sounds good thanks. any place in particular you recommend to order gatorbacks online?
Old Oct 7, 2012 | 03:21 PM
NukeC5's Avatar
NukeC5
I ebay things when I can.. very cheap, but maybe some vendors have them.
Old Oct 7, 2012 | 06:23 PM
red03vette's Avatar
red03vette
thanks for your help and time. i may have found the Gatorback's at my local "Canadian Tire" outlet, going to have to go out there and see.
doing a little more research on the forum and one other problem seems to be causing some squealing, the harmonic dampener. i sure hope that is not my problem. i do remember looking at the balancer while my engine was running and did not notice any wobble.
Old Oct 7, 2012 | 08:19 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Inspect the ac tensioner bracket housing. The bolt that secures it can cause noise.
Old Oct 7, 2012 | 08:43 PM
SFL_driver's Avatar
SFL_driver
I got both belts for $35 from amazon
Old Oct 7, 2012 | 10:45 PM
red03vette's Avatar
red03vette
ok, thanks.
Old Oct 7, 2012 | 10:46 PM
red03vette's Avatar
red03vette
amazon? never thought of that for car parts. thank you, i'll check it out
Old Oct 8, 2012 | 03:37 AM
LoneStarFRC's Avatar
LoneStarFRC
That's where I found mine for the best prices.
OP: Also wire-brush/clean the grooves on your pulleys and crank balancer. Don't just assume that because they "look OK", they don't warrant cleaning. Dirt/sand/grit can get embeded in the grooves and not be readily apparent with a quick look.
HTH
Old Oct 8, 2012 | 05:16 PM
red03vette's Avatar
red03vette
HTH
that's a good tip there! thanks i am guilty of just giving it the quick look, i will make sure after i change to the new pulleys that i clean the others before belt reinstall.
To ac pulleys
