[Z06] Installed DTE trans brace
Old Dec 1, 2016 | 04:04 PM
MY03C5Z's Avatar
MY03C5Z
Originally Posted by stratsRR
I couldn't imagine installing in the car!I istalled mine when I did clutch,trans rebuild.
Install would be a piece of cake with trans/diff out of the car. Installing while trans/diff is in the car was doable, but a royal pita....lol.
Old Dec 13, 2016 | 05:23 PM
NJ_phil's Avatar
NJ_phil
Just got done installing the ECS brace in my car and it was a bitch. They use a single top trans bracket for the 2 top rods and 2 separate trans brackets for the lower rods. The top bracket was almost impossible to get it while the trans was in the car. DTE has 2 side brackets for the trans to mount all 4 rods and is so much easier to install. Plus one of the top rod on the ECS brace is mounted on a pretty severe angle so forces pulling the rear and trans together are not equal.
Hope you bought the DTE
Old Dec 13, 2016 | 05:37 PM
zeevette's Avatar
zeevette
Well, it's a C6, so...
Old Dec 13, 2016 | 06:04 PM
NJ_phil's Avatar
NJ_phil
C5 is same mounting setup on the trans...rear is a little different
Old Dec 13, 2016 | 06:05 PM
furious427's Avatar
furious427
I received my ECS brace yesterday and starting installing today. Yah it's a pain but it's not that bad, I have about 4hrs in it so far taking my time. I am working under the car on jack stands. The top tranny bracket wasn't that bad you just have to use the right extensions and swivels. I have everything mounted except for the 2 lower tension rods and they are the easy ones to do. All in all it's not to bad, it's worth doing for the added insurance in my opinion.
Old Dec 13, 2016 | 06:09 PM
NJ_phil's Avatar
NJ_phil
Just got mine done today and also did it on jack stands in the garage...25 degree Jersey weather. Took about 6 hours and used just about every swivel socket and crows foot in I had. GL
Old Dec 21, 2016 | 07:24 PM
jallen355's Avatar
jallen355
Originally Posted by HoosierPE
We offer a brace similar to the Pfadt, and it controls the drivetrain torque reaction which helps plant the tires and reduce/stop wheel hop which is hard on the case, axles, and can cause other driveline problems. We also have the DTE differential business
We offer $50.00 off (25.00 each) when both the strut and mount are purchased together.
Thank you,
Scott
Looks like the diff brace is not available currently. According to your website...?
