Small exhaust problem
Old Oct 14, 2012 | 11:39 AM
carsangelop's Avatar
carsangelop
Default Small exhaust problem
Just noticed the pipes on the pass side are hanging a little low.Had a looking under and it seems the weld is broken where the pipe goes into the flange at the end of the H pipe just before it goes over the diff.
Car is a 98 vert auto stock exhaust with 16 K on the clock.Hope I described this right
Is this common problem?Easy fix?Think one of the chain exhaust shops could handle this ? Thanks
Old Oct 14, 2012 | 11:54 AM
NukeC5's Avatar
NukeC5
You can go into any muffler shop and have it welded back up without worrying about leaks. They deal with this sort of thing all the time.
Old Oct 14, 2012 | 11:59 AM
bumble-z's Avatar
bumble-z
Yes, it is a common problem.
The repair will only be as good as the welder that does the fix.
Old Oct 14, 2012 | 12:18 PM
jrose7004's Avatar
jrose7004
Your local exaust shop can handle it. Unless you're talking TI's.
Old Oct 14, 2012 | 12:22 PM
carsangelop
Thanks Will look into it tomorrow
Old Oct 14, 2012 | 12:23 PM
66BBDriver's Avatar
66BBDriver
Wounded Warrior Escort '11
St. Jude Donor '05
You have standard pipes on a '98 vert. All will be fine at a local shop. Only Z06's ran TI pipes.
Old Oct 14, 2012 | 01:25 PM
knewblewkorvette's Avatar
knewblewkorvette
with all the above
To Small exhaust problem
