[Z06] Cam Choice
Old Oct 19, 2012 | 02:36 PM
blades11b's Avatar
blades11b
Default Cam Choice
I know this can bring quite a few opinions so I would love to hear everyones. Im looking to upgrade the cam in my Z and wondering a good choice to go with here are my goals
1: AutoX/Roadracing with the occasional blow the dude in the mustangs door off in town
2: still pass smog (gotta be able to pass the sniffer here in Cali)
3: not buck too much under 1500 rpm
4: Leave a little room to grow when i finish up doing heads, headers and intake.
5: a nice good lope to it as well
Old Oct 19, 2012 | 05:55 PM
Paul 75 L82's Avatar
Paul 75 L82
Spend a couple of days on YouTube and listen to as many cams as you can. Find a few you like then come back to the forum and you'll get better info then. It's so hard to recommend a cam when you don't know what your looking for.
Old Oct 19, 2012 | 06:08 PM
ctusser's Avatar
ctusser
I believe a 224/228 duration is about as big as you can get away with in Cali and still pass emissions. There's some good known tuners in Cali, might want to pick their brains as they'll be able to tell you exactly what you can get away with and what to expect performance wise.
Old Oct 19, 2012 | 10:15 PM
Solofast's Avatar
Solofast
You really don't want much, if any more cam than a stock z cam if you are into autocross and road racing. The problem is what when the engine comes "on the cam" it will break the back tires loose and you will find yourself looking out the side windows at where you are going.
In autocross you already have enough power to spin the car if you get too deeply into the throttle, since you very rarely get out of second gear, and this is coming from someone who is using Hoosiers already. Even if you are on R compound tires there isn't much that more power is going to buy you. There was a recent post on the autocross and road racing forum comparing a car with a lot of mods to a stock car and the time difference was only .6 seconds. That tells you a lot about what mods are worth.
You need the power to come on smoothly as you are exiting the corner in both autocross and road racing, and that is far more important than just a peak power number. Drag racers can use a lot more cam than road racers for that simple reason.
Headers and some head work are fine if it helps high end breathing, but grip and corner exit speed are a lot more important to lap times than pure power. Look at how fast a lot of cars with a lot less power are if they have more grip...
And lastly, the mods you make to suspension keep giving performance for years, very little upkeep other than tires. The C5Z is pretty hard on valve springs already. If you go bigger on a cam you are asking for reliability issues if you do much track work.
Old Oct 20, 2012 | 12:29 PM
skyavonee's Avatar
skyavonee
My cam results may be of interest to you. You can still go a bit bigger than this while passing the sniffer.
corvetteforum.com/c5-z06-discussion/dyno-gains-from-219-223-607-610-cam-results.html
Where do you live? If you plan to have a performance shop do the tuning for you, you're best bet is to speak with them first to see what they've had luck with in the past. And if they're a decent shop, they'll have more experience than just about any of us responding to this thread.
Old Oct 20, 2012 | 02:01 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
Our CCP Stage 2 will fit the bill, 226/230 on a 114+2. It will drive really nice, pass emissions and make an easy 410+.
Right now we have cam kits on sale from $689 shipped ( cam, .660 lift dual springs, pushrods ) or cam only for $389.
Old Oct 21, 2012 | 06:55 PM
blades11b's Avatar
blades11b
whats the lift on that specific cam package? have any videos? and 410 to the wheels?
Old Oct 21, 2012 | 07:18 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
we've got what you need and it will meet or exceed your list below.
PM or call
Old Oct 21, 2012 | 07:52 PM
skyavonee's Avatar
skyavonee
PM or call
Old Oct 21, 2012 | 09:08 PM
Arun@CCP's Avatar
0Arun@CCP
Former Vendor
.605/.609
It will make 410 min.
Idle clip of mild
to wild:
You can get lots of feedback on our cams from C5 FI section.
To Cam Choice
