pfdat issue HELP
Old Oct 29, 2012 | 05:22 PM
didntdoit11's Avatar
didntdoit11
St. Jude Donor '12
Default pfdat issue HELP
hello i was wondering if anyone else who used pfdat motor mounts has had this issue? with the pins not lining up and with the way they face one in and one out see pics
thank you
pin not fitting
pins not fiiting
two different directions (yes i am **** about things like this lol)
Old Oct 29, 2012 | 08:30 PM
JimZRyd's Avatar
JimZRyd
St. Jude Donor '12
Wish I could help but here's a bump to the top to see if anyone else can. What are you building?
Jim
Old Oct 29, 2012 | 09:04 PM
m6 c5's Avatar
m6 c5
Send PFADT a message, Im sure they can offer some advice.
Old Oct 29, 2012 | 10:02 PM
robert miller's Avatar
robert miller
Could just be a mistake on there part and will replace them for you. Great CO. to deal with from all the parts I have of PFADT on my car. Give them a call tomorrow and send them a pic,s of the problem.. Robert
Old Oct 30, 2012 | 11:10 AM
Pfadt Racing's Avatar
Pfadt Racing
There is a very simple fix to both your problems, just as we emailed you yesterday. That alignment pin is simply an installation tool, takes absolutely no load, and is just pressed into the orange housing. Given that you've got the entire subframe removed and no engine installed you aren't going to need that alignment pin. Pull the pin out of the orange housing and flip the mount around 180 degrees. You will see absolutely no detrimental effects on performance or longevity by removing the pin. Occasionally the position of the hole in the factory subframe can be a little off, the pin is just there to make the mount a little easier to install but it absolutely does not have to be there for the mount to function properly.
This solution fixes both of your problems. The mount will now sit flush onto the subframe so you can properly bolt it up, and the laser etched Pfadt logos are now turned the same direction.
If you have any questions please let me know. My email address is jarrett@pfadtracing.com, or you can reach me at 1-888-972-2464.
To pfdat issue HELP
