I took the vette for a cruise tonight and after driving for awhile the turn signals quite working. I stopped for gas and they started working again then a few minutes later they quite again, then the next turn I made they were working again. Any ideas what it might be. I'm thinking it might be a ground problem, if so any ideas where the ground is for the turn signals?
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
Common issue with the C5, Next time it doesn't work push the 4 way switch in and out about 5 times and see if they start working, Turn lights are tied into the 4way, An easy fix is to buy one of these and install it.
Mr.Bill http://shop.jwmotoring.com/product.s...2&categoryId=4
I just started having the same problem. At first all I had to do was push the Emergency Flasher button once and my turn signals would work fine. But now, I have to push the Emergency Flasher button more than once to get them to work. I don't have LED's, will this harness still fix the problem or should I replace the Emergency Flasher button?
yeah...good luck....turns out the OP left out some important facts like his wasn't in there good so it popped right out....I gave up long after 18 minutes
For me it wasn't bad - you have to remove the radio/console bezel (which I had to do to replace my HVAC controls anyway). Once you have the bezel off the trickiest part is getting the old switch out. It's a tight fit but it is doable. I'll admit it took me a lot longer than 18min. LOL Took me that long to find the tools, and get the bezel off!
I added a Hyper Flash to correct my turn signals and it worked well for a while, then it went back to it's old inconsistant ways. Do these things go bad or get old ?
