LED Interior installed... (Red)
Nov 18, 2012 | 02:06 PM
Nov 18, 2012 | 04:45 PM
Nov 18, 2012 | 04:58 PM
Nov 18, 2012 | 06:02 PM
The LEDs places in stock location or is this aftermarket LEDs? Looks good I'm going to do blue is this a kit?
Nov 18, 2012 | 06:07 PM
I like it, looks mean!!!
Nov 18, 2012 | 06:25 PM
Very well done - looks great!!!
Nov 18, 2012 | 08:58 PM
C5 COTM Coordinator
Very good outcome
Nov 18, 2012 | 09:01 PM
The LEDs look really good. Will add these to my interior some day.
Nov 18, 2012 | 10:10 PM
Thanks men,,,, It looks so much better in person. Still need to install my door LED's... Will tackle that next. Tim does great work.
Nov 18, 2012 | 10:12 PM
So? Do these go in place of stock bulbs?
Nov 18, 2012 | 10:17 PM
Yes Sir... they are all replaced, soldered etc..
Quote:
Originally Posted by
Kevin300a
Nov 18, 2012 | 11:51 PM
C5 of the Month 6/13
Nov 19, 2012 | 12:23 AM
Nov 19, 2012 | 01:09 AM
Looks great!
I've had my red LED strips for months. I ordered 194 bulb adapters from fleabay for a couple of bucks, so I can hook everything up.
Can't wait to install them!
Nov 19, 2012 | 05:30 AM
St. Jude Donor '11-'12-'13-'14-'15
Thanks for the kind words Matt, the lighting looks great! I should loan you my camera though!
IF you ever want to convert your gauges (IPC) to red, get ahold of Xtremevette.
What I do is solder in 5mm or 3mm LEDs into the stock locations at varying angles and depths and sometimes multiples to get the best lighting effect possible. A few buttons I have to drill into and embed an LED right into it.
A plug and play type 74 NEO wedge (the majority of our bulbs) work really well in a few areas like the door switches and sometime the trunk release/fog lights switch, everything else really needs to be custom installed...
Tim
Nov 19, 2012 | 12:00 PM
From: Wylie TX --> Less is More, except under the hood !
Looking good Matt !
Were the "only" 2 in our group to have the full LED mod done...
Who is next ?
Toque
Nov 19, 2012 | 09:13 PM
Nov 19, 2012 | 09:18 PM
3318C5
Nov 20, 2012 | 03:25 PM
Mark, you and i will probably remain the only two... None of the others are as ****/OCD as you and i...
Toque
Looking good Matt !
Who is next ?
Toque
Nov 20, 2012 | 03:46 PM
0H1Z06
I don't think anyone else in our group is crazy enough to do it...
Toque
