having problems with '02 driver's side window switch
I have recently bought a 2002 Vette. When I roll down the driver's side window, it's seems to stick, because the volts go down and seems to be tripping something in the gauges...they gauges are going out, the window won't roll up, the speedometer and the batter amp gauge are the only two that work, all other gauges quit working. I can turn the car off and all the gauges go back to working but the window won't roll back up. I can usually let it sit, or disconnect the battery and then the window will usually roll up. Thought these issues weren't a problem with 02 models. Any help will be appreciated. Also, there has been an aftermarket radio put in it and after having it for a day, the front speakers have completely stopped working. The amps in the back are working but the speakers won't produce any sound...any suggestions?
