[Z06] 02 Z06 died!!
Old Nov 27, 2012 | 09:01 PM
ctusser's Avatar
ctusser
Originally Posted by crAzy03Z06
$7100 is little much for a stock LS6. Like others have said. You can get a better engine at a lower cost.
$7100 for a replacement motor and all the labor to do it is high? What do you think is a better motor plus removal and install price?
Old Nov 27, 2012 | 09:27 PM
PeteZ06's Avatar
PeteZ06
St. Jude Donor '07-'08-'09-'10-'11
Removal and install should be around $1000
So how I see it... if the guy is quoting you $7000 for everything then you have $6000 to spend on another engine. For $6K you can build a stout 383 out of your block. Find a reputable engine builder in your area or shop around on this website.
Old Nov 27, 2012 | 11:58 PM
Wood81's Avatar
Wood81
This, or get a block from a vendor and what parts you need, you can get an LS6 block from texas speed for 1000$ and to swap most of your old parts over shouldn't be that expensive
http://www.texas-speed.com/c-524-engine-blocks.aspx
