Headlight Question
Old Nov 22, 2012 | 08:37 PM
nutseynut7's Avatar
nutseynut7
Default Headlight Question
My garage is a little on the dark side,so when I start the car lights automaticaly go on till I back outside then they close. Is there any way to delay this so they wont wear out to quickly.
Old Nov 22, 2012 | 09:20 PM
c6miller's Avatar
c6miller
You can program your options (button #4)to cancel the twilight function.
Old Nov 22, 2012 | 09:43 PM
VETJAZZ's Avatar
VETJAZZ
turn off twilight sentinel
Old Nov 23, 2012 | 09:38 AM
If you have an owner's manual, look in there for the procedure. If you don't have one, you can download an electronic version from this web site under the downloads tab: www.gmpartshouse.com.
Old Nov 23, 2012 | 07:01 PM
C5FORFUN2's Avatar
C5FORFUN2
Also leaving the ebrake on 1 click or more should keep them off until you are ready.
Old Nov 24, 2012 | 01:20 AM
El original's Avatar
El original
Unless you have a Canadian car... then you gotta live with it! There are much worse things in life to contend with, like winter!!!!
Old Nov 24, 2012 | 01:46 AM
tak06's Avatar
tak06
Not really, pull relay #44 in the footwell fuse box in a Canadian C5 and that will disable your twilight sentinel.
Old Nov 24, 2012 | 01:53 AM
DeeGee's Avatar
DeeGee
Twilight (Optional in United States,
Standard in Canada)
Press the OPTIONS button until TWILIGHT - OFF
appears on the display, then use the RESET button to
page through the following selections:
 TWILIGHT - ON
 TWILIGHT - OFF
If you choose TWILIGHT - ON, press the OPTIONS
button again to display DELAY TIME 1 2 in the DIC.
Use the OPTIONS button to switch between delay time
1 and 2. You can increase the delay time by pressing
button 1 (1 FUEL) or decrease the time by pressing
button 2 (2 GAGES). Each bar is equal to 12 seconds.
To Headlight Question
