What general maintenance do you do?
So I'm asking everyone, what do you do daily, weekly, or monthly to your Vette?
Thanks,
Jack
I drive maybe 4K/yr...so It gets changed once a year.
Our cars have oil life monitors, change your oil when it gets to 0%, or once a year, whichever comes first.
Engine Oil Scheduled Maintenance
Change engine oil and filter as indicated by the
Engine Oil Life System@ (or every 12 months,
whichever occurs first). Reset the system.
Your vehicle has a computer system that lets you know
when to change the engine oil and filter. This is
based on engine revolutions and engine temperature,
and not on mileage. Based on driving conditions,
the mileage at which an oil change will be indicated can
varv considerablv. For the oil life system to work
properly, you must reset the system every time the oil is
changed.
When the system has calculated that oil life has been
diminished, it will indicate that an oil change is
necessary. A CHANGE OIL SOON message will come
on. Change your oii as soon as possibie within the
next two times you stop for fuel. It is possible that, if you
are driving under the best conditions, the oil life
system may not indicate that an oil change is necessary
for over a year. However, your engine oil and filter
must be changed at least once a year and at this time
the system must be reset.
This topic =
and usually ends when blackstone results get posted.
Peter
PS - Anti venom mod - http://forums.corvetteforum.com/c5-g...procedure.html
Peter
It's basically adding a copper washer to a deten plug on the transmission. You can read the procedure at toquez06.com
