Complete fluid change cost
Old Nov 28, 2012 | 02:31 PM
Jackb0524's Avatar
Jackb0524
Default Complete fluid change cost
I got a quote from a great place by the house. They will do complete fluid change, oild change and full fuel system clean out for around $930
This a good price?!?! Seems steep.....
Old Nov 28, 2012 | 02:48 PM
dblerman's Avatar
dblerman
Price of the fluids alone should only be around $100-150 and that's for oil, coolant, transmission, and differential. Not sure if "complete fluid change" includes brake fluid. If you were to get all these things done separately it shouldn't be more than $300-400. If the shop is doing it all at the same time while it's on a lift it should cut the labor time significantly.
I would turn and run if I were you.
Heck, if you were local I would do the fluid change for you in my driveway on jack stands for the cost of beer and pizza.
Old Nov 28, 2012 | 02:52 PM
Maxx_Z06's Avatar
Maxx_Z06
C5 COTM Coordinator
You could easily do all of them yourself. There's tons of DIY threads around here with excellent information on how to do it. Save yourself the money.
Old Nov 28, 2012 | 03:07 PM
maxx2200's Avatar
maxx2200
This place is awesome!
I thought you were being facetious $930 sounds like theft to me.
Old Nov 28, 2012 | 03:14 PM
Jackb0524's Avatar
Jackb0524
It seemed steep to me but I wanted to ask first. $930 was the actual quote
Old Nov 28, 2012 | 03:17 PM
dblerman's Avatar
dblerman
I'd love to hear the shop explain how they arrived at that number
Old Nov 28, 2012 | 03:22 PM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Originally Posted by dblerman
Price of the fluids alone should only be around $100-150 and that's for oil, coolant, transmission, and differential. I would turn and run if I were you.
$150 should get you all of the above fluids including brake fluid (for brakes and clutch) and a hand pump.
Helpful DIY links:
http://97vette.com/
http://mysite.verizon.net/res0aae8/webpage.html
http://forums.corvetteforum.com/c5-t...l-in-here.html
Old Nov 28, 2012 | 03:38 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Way too high!
My C5 turned 7 years old last year, so my local club sponsoring dealership performed the following for $500:
- Oil Change/Filter
- Engine Coolant System Flush
- Brake Fluid System Flush
- Power Steering Fluid Flush
- Checked all hoses/gaskets
- Replaced wiper blades
- Installed my DSV steering wheel
I had performed all of the fluid maintenance myself up to that point and since I didn't want to mess with the airbag during the steering wheel swap, I had them replace all the fluids.
FruiTay's Avatar
FruiTay
Default Toque's website....
I like this forum member's website, Toquez06.com. This guy rocks and has easy instructions:
http://toquez06.com/
Old Nov 28, 2012 | 04:11 PM
Jackb0524's Avatar
Jackb0524
Thanks for the info guys!!! Figured it was to high
Old Nov 28, 2012 | 05:50 PM
hockeyspokes's Avatar
hockeyspokes
$930 bucks is feciecius ! :>) YIKES
Old Nov 28, 2012 | 07:23 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Yep, way too high.....
Old Nov 28, 2012 | 07:30 PM
Toque's Avatar
Toque
From: Wylie TX --> Less is More, except under the hood !
Helpful DIY links:
http://97vette.com/
http://mysite.verizon.net/res0aae8/webpage.html <---NOT ACTIVE ANYMORE
That is my old web site.... Verizon has it locked and I can't delete it...
Please refer to my new web site.... www.ToqueZ06.com
Jack:
Check out my web site above. I have some easy peasy procedures to some stuff that can help you out.
I still need to add oil change procedure, and a coolant procedure. I will do that in the spring when I'm getting it ready for the summer heat.
I'm always adding new stuff on there !
Toque
Old Nov 28, 2012 | 09:31 PM
$930 is insane for fluid changes. I would agree, you should be able to get all the fluids done for $350-400 tops.
Old Nov 29, 2012 | 03:17 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Ahhhh....No
Peace
Chip
__________________
..................Click for
Old Nov 29, 2012 | 04:08 PM
maxx2200's Avatar
maxx2200
Old Nov 29, 2012 | 04:21 PM
GK's Avatar
GK
A local Pennzoil shop did my tranny, diff, radiator, brake and oil all for around $130. I used a $10 off coupon from their site. Very reputable shop. All the guys in the bay are gear heads and took extra precautions. Even covered my windshield up.
Keep looking dude.
To Complete fluid change cost
Old Nov 29, 2012 | 07:39 PM
TorchRedRocket's Avatar
TorchRedRocket
Dealership quotes/rates never cease to amaze me.
Old Dec 6, 2012 | 09:38 AM
JeffreyDurbin's Avatar
JeffreyDurbin
Default I wish I knew you before I drove my Vette out west!
Wow, you work cheap! I left my '97 with a buddy in Los Angeles and the shift from 1st to 2nd is a bit rough so I offered to buy his family dinner if he does the swap instead of bringing it to a shop.
Old Dec 6, 2012 | 10:33 AM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Last winter I did the complete fluids swap myself. Car had only 21k miles at the time. The cost of the fluids plus a hand pump, oil and air filter was $202. The fluids were all OEM from a dealership except the trans which was Amsoil and Mobil 1 oil and Mobil 1 filter on sale from Advance Auto.
This year, I did them all again except the coolant. Wanted to see what was going on after driving the car (only) 3k miles since last year.
Bottom line: oil changes of course are a no-brainer. Diff, trans, and brake fluids came out looking like new - put a drop of the old and new side-by-side on a white paper towel and you can't see a difference.
Clutch fluid (DOT-3) clear but slightly darker than new. Power steering the same.
