Lifting pucks
Old Dec 5, 2012 | 12:54 PM
thmehr's Avatar
thmehr
Default Lifting pucks
HI
I need to make some lifting pucks today. My plan is to use a hockey puck. I see that some posts are using 1 puck and some are using 2 pucks. My questions is, for those have used just the one puck, have you had any issues?
Ted
Old Dec 5, 2012 | 12:58 PM
jpalamar's Avatar
jpalamar
1 puck is just fine. Just screw an eye hook in and use some epoxy and your all set.
Old Dec 5, 2012 | 01:01 PM
VETJAZZ's Avatar
VETJAZZ
I used the orange pucks which are heavier - used for practice.
Old Dec 5, 2012 | 01:16 PM
One puck should be just fine. I use BMW lifting pucks and they are not as thick as a hockey puck but work OK.
Old Dec 5, 2012 | 07:41 PM
The Chair Man's Avatar
The Chair Man
Default Hockey puck lifters
Anyone know the size of the eye hook needed for home made hockey puck?
Old Dec 5, 2012 | 08:09 PM
bighank's Avatar
bighank
Default I drilled mine and used 2 nuts not a lag screw
Bolts won't slip or pull out if you drill thru the puck and countersink the nut which will contact the jack or lift arm.
Old Dec 5, 2012 | 09:59 PM
PaConehead's Avatar
PaConehead
I have a set of four (single) w/lag screw eye bolts - they turn right in the slot and tighten down snug. I also keep one without a eye bolt that can sit on my jack plate. Works great either way.
Old Dec 6, 2012 | 10:29 AM
dave89gta's Avatar
dave89gta
This video was posted here a while ago. It may help you.
http://www.youtube.com/watch?v=BXPffFGBOwg
Old Dec 6, 2012 | 11:41 AM
alxltd1's Avatar
alxltd1
St. Jude Donor '10-'12-'13-'14-'15-'16-'17
Here you go
http://forums.corvetteforum.com/c5-g...ck-thread.html
Old Dec 6, 2012 | 05:53 PM
killain's Avatar
killain
Oldtimer
Default Lifting pucks ?
Originally Posted by alxltd1
These work perfect !
To Lifting pucks
