Headlight Crank
Old Dec 11, 2012 | 11:42 AM
c5BlackBeauty's Avatar
c5BlackBeauty
Lifetime Member
St. Jude Donor '05, '12-'13, '15-'16, '21
Default Headlight Crank
I am in process of swapping out my headlights and I thought I would go ahead and switch the headlight motor gears. I've done one so far but I am apparently missing a step. When I turn the crank, I get nada and I suspect there is a problem or I did something where the gear isn't engaging. Anyone had this problem or have a suggestion? I searched but I couldn't find anything specific on this issue. Thanks
Old Dec 11, 2012 | 12:59 PM
Phanni's Avatar
Phanni
One way to 'cheat' the system is to turn on the headlights, then rasie the hood and disconnect the plug at the lights. they will then stay up while you work on them and they will not have any power to light up....
Old Dec 11, 2012 | 06:39 PM
c5BlackBeauty
Lifetime Member
Thanks for that but my problem is that the manual crank doesn't appear to engage. Any other suggestions.
Old Dec 11, 2012 | 11:54 PM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
Try twisting the crank while lifting the headlight itself with your other hand. The plastic gear may be gone so bad it needs a little help catching on the worm gear.
To Headlight Crank
