Is an ipod hookup possible?
What Ipod/iphone were you using?- if iphone 5 you MUST use the 30 pin adapter
Did you connect set the dip switches to 3 and 8 to on position? this HAS to be done
did it show it was charging? If the unit is charging than it was connected and dip switches were either not set or
I dont recall but if you have used the pxhgm4 option and have a cd changer did you disconnect the changer from back of radio as well?
did you press play on ipod?
are you using an iPhone 5? if so you need the 30 pin adapter as this is an Apple issue not iSimple
These are just a few things that are the first for me to ask everyone who have problems on install
I get calls all the time when something is not working correctly and the first thing to assume is it is the product when it simply is something wrong on install. Once we figure it out the product always works fine. Normally its a wiring issue on a radio. But we take the time to walk throught he install and see what is wrong. Might take a few minutes to do as its hard to trouble shoot something when your 1000 miles away and going off info given to you on the phone.
Offer still stands to send back for refund.
Dennis
cd changer connection
http://shop.doubledmods.com/ZUNE-C5-...?categoryId=-1
no cd changer connection
install is same as the ipod
Will this charge my phone?
I am trying to decide whether to use my phone (android) or leave an ipod in the car.
Tim
