Is an ipod hookup possible?
Old Dec 12, 2012 | 03:47 PM
Brooksbro91's Avatar
Brooksbro91
Default Is an ipod hookup possible?
How's it going gents?
So, another question coming your way...Is there a way to get an ipod (or USB) hookup without changing out the original radio? I've used one of the set ups that plug into the car's lighter, and set to a certain frequency, playing the ipod through that station, but those are way too static-y. Is there a better, not overly expensive (<$250) solution?
Old Dec 12, 2012 | 03:59 PM
RetiredSFC 97's Avatar
RetiredSFC 97
St. Jude Donor '09-'10, '14
contact dennis at Double D Mods
http://www.doubledmods.com/
He is a vendor here and will help you.
Other than that I don't know myself unless you have a cassette, then you can get one of those thingies that use the cassette and then plug into your ipod. Not the best but doable. I have one in my STS and it's "OK"
Old Dec 12, 2012 | 04:37 PM
Brooksbro91
Thanks! I'll check them out.
Old Dec 12, 2012 | 06:28 PM
tlove32's Avatar
tlove32
The answer is yes - this is what you need:
http://shop.doubledmods.com/Peripher...PXDPPXHGM2.htm
Old Dec 12, 2012 | 07:05 PM
Bill Vett's Avatar
Bill Vett
I've had mine for about 5 years now and still love it. No more CD's sliding around, none falling on your lap from the visor, just 1376 songs at your finger tips.
Old Dec 12, 2012 | 07:33 PM
Lloyd Christmas's Avatar
Lloyd Christmas
Does that gizmo work if you don't have a cd changer? I mean, if you don't have that option, does the harness still allow you to plug it up?
Old Dec 12, 2012 | 07:40 PM
chris04gto's Avatar
chris04gto
Yup
Old Dec 12, 2012 | 07:59 PM
Lloyd Christmas
awwww yissss
Old Dec 12, 2012 | 09:03 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
if you have a cd changer
you want this one
http://shop.doubledmods.com/Peripher...?categoryId=-1
If you do not have one
You need this one
and this is link to installiinstructions for the no changer option
http://www.doubledmods.com/uploads/i...and_PXHGM4.pdf
Dennis
Old Dec 12, 2012 | 10:31 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
No! ..I tired two and neither ever worked! Still have one holding down some paper on my desk new in the box. Want to try it? PM me.
Old Dec 12, 2012 | 10:36 PM
0Double D Mods
Former Vendor
We shipped out over 200 PXDP and PXDX kits last month alone and not a single issue and for you to have 2 that dont work tells me you did have it connected correctly.
Old Dec 12, 2012 | 10:38 PM
0Double D Mods
Former Vendor
odds are if you have no changer you have no harness and would need to connect to the back of the radio using the options I listed
Old Dec 12, 2012 | 11:26 PM
Lloyd Christmas
OK. Using this model, does it control the Ipod through the stereo controls or do you have to use the Ipod controls?
Old Dec 13, 2012 | 02:42 AM
Mallett Z's Avatar
Mallett Z
2015 C5 of the Year Finalist
St. Jude Donor '07-'08-'09
My car has no changer and the stock radio has an AUX button to control the ipod. The radio controls will work to forward/reverse the track. just put the ipod on shuffle and leave it in the glovebox or center console and forget about it.
Old Dec 13, 2012 | 07:08 AM
0Double D Mods
Former Vendor
you have VERY limited controls with the radio. forward and reverse and thats about it. This unit will also charge the ipod as well.
You are mixing technology from early 90's with todays ipods. The pxdp will allow the ipod to connect through the stock system, charge and some controls yes.
Old Dec 13, 2012 | 08:45 AM
MikeMikeWmike's Avatar
MikeMikeWmike
Is there something that can be done with this setup to make it work with just an aux cord? I love this setup but I have an android phone that i'd like to use instead of an iPod
Old Dec 13, 2012 | 09:19 AM
0Double D Mods
Former Vendor
for aux input
cd changer connection
http://shop.doubledmods.com/ZUNE-C5-...?categoryId=-1
no cd changer connection
install is same as the ipod
To Is an ipod hookup possible?
Old Dec 13, 2012 | 10:18 AM
MikeMikeWmike
for aux input
Zune.... way to go microsoft!!! Thanks for the info!! Will the factory CD player still work after this is installed or does this disable it?
Old Dec 13, 2012 | 10:31 AM
0Double D Mods
Former Vendor
cd player in the radio yes will work
CD changer will not work as if you do have one and use the connection for back of radio you have to disconnect it there too
Old Dec 13, 2012 | 10:55 AM
Bobd207s's Avatar
Bobd207s
From: Cancer Sucks - please donate to Corvettes Conquer Cancer
Cruise-In X Veteran
St. Jude Donor '08-'09
Got mine from Dennis and it works great !!
