Optima Red Top = free.
Old Dec 16, 2012 | 10:41 AM
INaband's Avatar
INaband
CI 7-8 Veteran
Default Optima Red Top = free.
Our car lot got a camry in with an Optima in service date 10/11.
My A/C Delco was slightly older, researched the 75/35 which is a correct fit
changed it out today.
Old Dec 16, 2012 | 10:45 AM
NukeC5's Avatar
NukeC5
Lucky find, make a difference in cranking or anything? I doubt it will do anything noticeable. Maybe if your old battery was really bad.
Old Dec 16, 2012 | 11:18 AM
Brackneyc's Avatar
Brackneyc
Not a fan of the red tops. For free, only if my current one was dead, but to pay for one....not a chance.
Old Dec 16, 2012 | 11:44 AM
INaband's Avatar
INaband
CI 7-8 Veteran
More cranking and newer.
Old Dec 16, 2012 | 12:40 PM
calivette805's Avatar
calivette805
those dont like garage queens i drive my vette once a month for the past 3 years and gone threw 2red tops
Old Dec 16, 2012 | 12:49 PM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
If your car is going to sit for a week without driving it invest in a Ctek for it, You will need it.
Mr.Bill
Old Dec 16, 2012 | 12:51 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
Mr.Bill
I agree
and would have kept the AC Delco myself
Old Dec 16, 2012 | 12:57 PM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Right on! Free is always good!
Thanks,Matt
Old Dec 16, 2012 | 02:14 PM
gotz06?'s Avatar
gotz06?
Junk!
Old Dec 16, 2012 | 02:20 PM
JaxEagle's Avatar
JaxEagle
Mr.Bill
I average a little over 200 miles per month on my car and I have a red top. I have definitely found this to be true. The upside of this is it forces me to find time to take the car out if even just for a short drive.
Old Dec 16, 2012 | 04:23 PM
Must_Have_Z's Avatar
Must_Have_Z
My car sits a week or more a few times a year and I've never had a problem with my Red Top. I only use my CTek when the car goes into storage over the winter. Red Top FTW!
Old Dec 16, 2012 | 04:55 PM
PHIL MEMPHIS's Avatar
PHIL MEMPHIS
Bad trade. Should have kept the one you had.
Old Dec 16, 2012 | 05:09 PM
Mr.Bill's Avatar
Mr.Bill
I have a red top in my C5 and in my 72 Camaro, The Camaro can sit for weeks at a time and still start right up, The Vette is another story.
The Red Top is a good battery if you use it is a car that isn't a volt hog as the Vette is. The Vette has so much draw all the time that the red top has a hard time keeping up, That doesn't mean the red top is a bad battery, Just that a Red Top isn't the right choice for a C5. I have had my Red Top in my Vette for 3 maybe 4 years now and no issues, But I drive it everyday.
Mr.Bill
Old Dec 16, 2012 | 07:06 PM
LT1driver's Avatar
LT1driver
would not put a pos optima in any car I owned...my opinion, to each their own
Old Dec 16, 2012 | 07:15 PM
JaxEagle's Avatar
JaxEagle
Mr.Bill
I believe that is the consensus. I will probably switch when the time comes.
Old Dec 16, 2012 | 07:17 PM
JaxEagle's Avatar
JaxEagle
fwiw, the optima warranty service is very good. I had one replaced with no questions asked. Just handed me a new battery at Autozone and the rep commented that Optima is very good about taking them back.
Old Dec 16, 2012 | 07:58 PM
jrose7004's Avatar
jrose7004
I had two Red Tops with absolutely no problem.
To Optima Red Top = free.
Old Dec 16, 2012 | 08:02 PM
VETJAZZ's Avatar
VETJAZZ
Old Dec 16, 2012 | 08:13 PM
duramaxsky's Avatar
duramaxsky
I have 2 in my pick up because the water running down the hood gap over filed the standard type and ruined it. It also made it leak. No problems at all. It almost never moves in the summer as I drive the Vettes. I also have one in my C5 and only hook up the battery tender for long storage. No problems with either. The Vette has the ECM right below it and a Red Top will never leak. I would put up with the other problems for that reason. But they have not happened. To each their own but my C6 will get one too. I hate to repair the corrosion damage.
Old Dec 16, 2012 | 08:39 PM
C5FORFUN2's Avatar
C5FORFUN2
Never had a problem with Optima's or AC Delco. Both have exceeded their projected life expectancy by years. Personally I would never use a battery with the removable top caps in any of my vehicles as they always have some acid residue coming out of them. Since the AC Delco professional changed to top caps I now use the AC Delco 60 series in the Corvette and the trucks. The Optima's in the ****** and the RV.
