FRC rear window question
Old Dec 22, 2012 | 06:43 PM
LT1driver's Avatar
LT1driver
Default FRC rear window question
99-00 FRC, will the rear window fit the zo6, same window???
are they available still and if not what do used ones go for??
thanks.
Old Dec 22, 2012 | 07:56 PM
64Corvette's Avatar
64Corvette
Default FRC back glass
Go to the thread C5 convertible removeable hardtop build REvised and go to the last page, find roc87 he mentions there is a back glass on Ebay. You might contact him.
Old Dec 22, 2012 | 08:01 PM
davek 515's Avatar
davek 515
I think they the frc and z06 are the same, they (gm) made that body style in '99-'00 frc then just added the z06 motor in car in '01. I think that is correct, if in different please help.
Old Dec 22, 2012 | 08:53 PM
Roc87's Avatar
Roc87
OEM are no longer available, my glass guy said he could order an aftermarket one for around $700. Oddly enough the OEM trim/seal is still available for around $85 through GMPartsDirect. Used glass from what I have found is around $300-$400 not including shipping, and yes, the glass is the same for the FRC as the Z
Old Dec 22, 2012 | 09:08 PM
Yes, I think they are the same windows too.
Old Dec 23, 2012 | 12:20 AM
LT1driver's Avatar
LT1driver
thanks guys
Old Dec 23, 2012 | 12:23 PM
CHJ In Virginia's Avatar
CHJ In Virginia
Call your local glass shops and get a quote. SafeLite has an exact replacement available as well as the gasket kit. $700 is way too high of a price. I would expect $5-600 installed with gasket to be a fair price.
Old Dec 23, 2012 | 02:29 PM
PhilsFRC's Avatar
PhilsFRC
Those are good prices-GM's parts data base lists the window right at $3000-which is insane.
To FRC rear window question
