Modify Headlights Half Open?
Old Dec 26, 2012 | 09:49 PM
remix919's Avatar
remix919
Default Modify Headlights Half Open?
Anyone know how to modify a set of stock C5 headlights so they open only halfway like the sun guns? I don't have sun guns and I'm looking at getting a custom set made but was just wondering how difficult it would be to modify the stock unit for only half open.
Old Dec 26, 2012 | 09:56 PM
Aerovette's Avatar
Aerovette
You'd never be able to aim them.
Old Dec 26, 2012 | 10:02 PM
remix919's Avatar
remix919
Not worried about that, I'll be making custom projectors, just wondering if the the adjusting part is a pain to keep it adjusted.
Old Dec 27, 2012 | 12:02 AM
momo20's Avatar
momo20
its not a Nissan..there is not enough adjustment to do what you want to make happen..you will have to do some pretty extensive mods to the gears and adjustment areas for it to even work .
Old Dec 27, 2012 | 01:22 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
The Sun Guns kit includes a custom made bracket that relocates the stop point.
Old Dec 27, 2012 | 01:42 AM
striper's Avatar
striper
Is the Sun Gun kit the one sold by Corvette Central? If not, they sell a kit too for half-opening lights.
Old Dec 27, 2012 | 09:11 AM
TheRadioFlyer's Avatar
TheRadioFlyer
Supporting Vendor
If you're going to jeep them adjusted, you'd need to build a hinge-add-on to use the factory stopper to lock the headlights in at the desired height. From there you can use either the factory adjusters or tinker with the spacing on the mounting points of your projector.
Old Dec 27, 2012 | 09:21 AM
remix919's Avatar
remix919
Do you have a link?
I found them at corvette central, they look kinda like sun guns but a bit different and they already have the shrouds available, but price is $1495 O.o!!!
Old Dec 27, 2012 | 11:11 AM
Fast one's Avatar
Fast one
Picture #1 shows the stock assembly with white nylon bumpers. Picture #2 shows modified stops. You could also make spacers that are welded on the existing stops with the nylon bumpers removed. A small block of steel with a tapped hole for an adjusting bolt would be easy to make and weld on. When the headlight motor controller reads a current spike from either motor it turns off the power to both motors; the current will spike when a stop prevents either motor from turning. http://forums.corvetteforum.com/c5-g...-ups-done.html
Old Dec 28, 2012 | 01:43 AM
striper's Avatar
striper
Do you have a link?
That's the kit I was referring to,I also thought the price was just atad too high. I'd buy lights from "George, Radioflyer" instead.
To Modify Headlights Half Open?
