This is a fitting that's easy to find if you decide to go to a filter that has no "nut" on the bottom.
I have one since at times I will use a Mobil1 or Bosch Premium filter if I cant find a kn. Its better used for removing the filter because sometimes I can be tricky getting the filter out of it. Gets wedged.
be careful when you use the K&N oil filter cause that tighten/losen nut on the bottom becomes a low point and could risk hitting something with the K&N compared to other brands
KN here. My car is slammed and the nut on the filter has never had a single mark on it from touching anything. Plus that nut is really helpful for easy install and removal.
Thanks for the warning but both of my C5s are lowered and yet to see a scratch on the K&N oil filter.
You are correct for my Eagle Talon TsiAWD though. Ever since I went with a 3" exhaust I can no longer get the K&N filter installed.
I've been using the Amsoil EA15K32 for a couple years now, but just realized the WIX 51042 is just as good, and a couple of dollars less. I might just move to that one on my next oil change....
AMSOIL carries both their own proprietary line made in partnership with Donaldson and Wix and they also carry Wix and Donaldson filters.
For my Vette at the track, I normally use the Wix 51042. For my street vehicles I normally use the AMSOIL Ea Oil Filter as I feel these provide better filtration. If I still used my Vette for daily driving and used short oil change intervals, I'd probably still use the Wix like I do at the track.
KDT2790 Features: -Specially designed wrench removes and installs hard - to - reach 3" (76mm) oil filters with a 15 - flute end.-It fits various flute designs found on AC/Delco, Farm, Wix, STP, NAPA, Sears, Gard, VW, Motorcraft and other filters.-Use with a 3/8" square drive tool or a 1" wrench.-Durable steel wrench is zinc plated to resist rust.-Be sure fluted end of filter matches wrench Caution - wear eye protection. Do not use with power tools. .-3'''' End Cap Oil Filter Wrench. Warranty: -Lifetime warranty does not cover abuse.
