Traction/Handling Problem
Old Jan 3, 2013 | 04:50 PM
dtang55's Avatar
dtang55
1st Gear
Default Traction/Handling Problem
I have replaced my active handling and Traction Control Computer Modeules twice over the past 5 years and now am getting the same message again. Does anyone know if there was a recall or whom to talk to at GM. They were replaced by the same autherized Chevy dealer twice and now I seem to need to replace them again. My cost was about $1,600.00 dollars each time. I want to have some info before I return to the dealer. Thanks Dom
Old Jan 3, 2013 | 05:12 PM
Phanni's Avatar
Phanni
Hi Dom, it'd help if we knew the year of your Vette. number of miles etc would help too. there can be many causes of this problem from bad grounds, bad sensor on the hubs, to the computer. If the EBCM has been replaced twice, I'd start looking at other areas. If you learn to read the codes you might be able to get some more help here...For instance if the error is always coming from one certain wheel or just one certain code shows up it would help identify the problem area.
Old Jan 4, 2013 | 11:09 AM
jpalamar's Avatar
jpalamar
http://www.absfixer.com/catalog/prod...8jth35ep89ruk4
Old Jan 5, 2013 | 04:20 AM
Phanni's Avatar
Phanni
What happened to the OP?
We chip in with info and he takes a hike....
To Traction/Handling Problem
