ebcm failure rates
Old Jan 8, 2013 | 04:41 PM
racebum's Avatar
racebum
Originally Posted by Dave68
That's where you'd be wrong. I know at least 6 past and present C5 owners (2000 and newer) and every last one has had the EBCM fail. The same is true of the column lock feature. What are the odds, then that the majority of C5 owners who have 2000 and newer C5s have NOT had their EBCM fail? I'm not talking about C5s with 5000 miles on them. Let's say 30,000 miles or more. Pretending that it's not a problem won't make it go away.
If you do have a 2000 C5 that has not had this issue, prepare! Your options are limited.
mileage isn't really a factor for the ebcm, age, moisture levels and the pick of the circuit is what matters. it's like any other electronic gadget, some live forever, some fail. there are 200k c5's on the oe ebcm and some that have failed on garage queens.
i still have a hard drive from 1996 in an old pc that works. i've also had drives fail within a month of buying. such is the nature of things
Old Jan 8, 2013 | 04:50 PM
Road_runner's Avatar
Road_runner
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
I've had two fail. 2000 and 2002
Both replaced with new GM parts from Ken Fitchner
Old Jan 8, 2013 | 04:56 PM
Greenlight88's Avatar
Greenlight88
It's my belief this system is more prone to fail if you are attempting to spin the back tires with the traction control activated. Mine failed 3 years ago, and it was a $4800 repair bill. The EBCM and BPMV had to be replaced. There was a steering column sensor that was also somehow affected and had to be replaced.
Old Jan 8, 2013 | 06:04 PM
racebum's Avatar
racebum
that's just nutty. how does one justify 1/3rd the price of a cars value for a couple electronic boxes.
Old Jan 8, 2013 | 06:50 PM
Greenlight88
I ran into a Chevy field service manager at a dealership open house and discussed with him. The car was 2 years out of warranty. He called 2 days later and said he'd fix it and cover all the costs, less $300 from me. I couldn't believe it. Neither could the local chevy dealer. At any rate, I had it repaired and its work fine since then. That was 2009.
Old Jan 8, 2013 | 09:56 PM
Dave68's Avatar
Dave68
The solder on some of the electronic components on the HAVAC PCA cracks and fails after so many years. Is this something that has to happen to 150,000 boards? Of course not; the person who selected the solder, selected the wrong solder. It has nothing to do with luck and everything to do with a bad design (just like the column lock system).
Why is it that my wife's 8 year old Lexus has never had its stabilty control, antilock, or any other circuit fail? GOOD DESIGN!
Now, the C5 has many good features that continue to work, but the ones that fail should be fixed with an improved componant/component assembly. My smog pump check valve (you know, the one waaay in the back of the intake manifold) just failed again for the 4th time. Most likely, GM will have the same valve to sell me.
Old Jan 8, 2013 | 10:06 PM
Dave68's Avatar
Dave68
Originally Posted by dblerman
6 is a LONG way from 250,000...Even if EVERY C5 owner on this forum had theirs fail it would be a fraction of 250,000.
And why should mileage matter? It's not a moving part that fails with the EBCM.
what are the odds? Make a thread with a poll and find out
When it comes to a circuit board assembly, it is often the expansion and contraction of the PC board and its components due to heating and cooling cycles. A garage queen car that sits for most of its life is less likely to see a failure as early as a car that is driven daily. Each travel-to-work day represents at least 2 hot and cold cycles.
Regarding statistics: Quality inspectors will inspect a certain percentage of parts, especially parts that have been changed or produced by a new vendor. Often, if one or more failure is found, an additional amount or the whole lot is then inspected. Why? because the statistical odds of finding more failures increases with every failure.
If I told you that everyone in my neighborhood had a pipe-bursting problem, would you claim that there is little reason to believe that either the pipe material or its assembly is suspect in every house built by that contractor?
Old Jan 8, 2013 | 10:20 PM
racebum's Avatar
racebum
it happens, sony made the same mistake on the 1st gen ps3. they didn't use silver solder on the chipset or video card. well, after hours of playing the heat was enough to micromelt. long story short, after so many hours they all are doomed to fail.
cars all have pros and cons. honda has some of the most reliable electronics of any car made.....but their engines are easy to blow up since the sporty ones like the s2000 have a 9000rpm redline
pros and cons
Old Jan 8, 2013 | 10:23 PM
dblerman's Avatar
dblerman
A car with 10K miles can have the exact same number of hot and cold cycles as a car with 50K miles. Also, you're forgetting that the EBCM on the 97 & 98 were located in the rear of the vehicle and wouldn't be subjected to such extreme hot/cold cycles as those found in the engine bay on the 99+ model. According to your theory that would mean we should see a higher failure rate on 99+ but I would be willing to bet there is no significant difference in rate between 97-98 and 99+.
Yes, and analyse whether the number of failures is statistically significant or whether it is due to random chance.
I'm sorry, you can't cherry pick, statistics don't work that way. My 13 year old C5 has never had an EBCM failure....must be because of the good design....see what I did there?
The difference is, not every EBCM is failing. In fact it's actually an extremely small fraction which gets a lot of attention due to it being:
A) Expensive
B) Hard to get a replacement
But with regards to your plumbing example...If it's just everyone in your neighborhood I would assume there was something wrong with the water pressure in your neighborhood. Unless you could point to the same problem in other neighborhoods that used that contractor and/or pipe material.
Old Jan 8, 2013 | 10:55 PM
dblerman's Avatar
dblerman
Are the C5 EBCMs a perfect design? No, obviously not.
Is there a chance that any given EBCM can fail? Yes.
Is that chance high? Not really.
Does it suck if it happens? Yes.
Should you waste your time worrying about whether it will happen? No.
Old Jan 8, 2013 | 11:58 PM
Jistari's Avatar
Jistari
Old Jan 9, 2013 | 09:51 AM
Dave68's Avatar
Dave68
This is precisely why many managers fail; they fail to plan for interruptions/failures.
Make no mistake, this issue is significant and it will happen. You should not worry about it ONLY if there is absolutely nothing you can do about it. Many folks who keep cars for far longer than average, prepare for obsolescence by buying parts BEFORE they are unavailable. Should none of us worry about retiring by not saving? Of course not - so to those who own pre 2001 C5s, plan, check, locate, contact. Doing so may mean the difference between selling your C5 for a big discount or keeping it as long as you desire.
Old Jan 9, 2013 | 09:53 AM
  #33
Dave68's Avatar
Dave68
Exactly - failure by design/specification, not a lack of luck. This is the case with many of the C5 components.
Old Jan 12, 2013 | 08:02 PM
  #34
goober51's Avatar
goober51
Got my ebcm back from absfixer. Put it back on, so far no codes.
Old Jan 13, 2013 | 08:48 AM
  #35
99 vett babycar's Avatar
99 vett babycar
that's the first piece of good news in this post !
