[Z06] Which cam c5z???
Old Feb 2, 2013 | 03:26 AM
Z06ness03's Avatar
Z06ness03
Taking the heads off a small block is relatively easy and can be done in somebody's drive way in about 2 hours. Most shops don't charge too much for milling (about $400-600) considering the gain. As far as lifters and trays that really comes down to the condition of his current lifters which are probably fine. If anything should be replaced it should be the valve springs with .600 lift springs which sure would be easy to do with the heads off. Also the stock injectors are good for around 435-450whp which he wont be making with a mild cam and milled heads. Just trying to offer some other options. Yes its more work and a few extra bucks. Is it worth it? hell yeah.
