Choice between 98 or 99
Old Jan 10, 2013 | 08:48 AM
lombardinh's Avatar
lombardinh
Cruising
Default Choice between 98 or 99
Looking to buy a 1998 conv with 52000 miles or 1999 conv with 71000 miles. Both are same price and are tripple black. The 99 needs conv top rear window repair.Glue came undone. Which would be better choice.
Old Jan 10, 2013 | 08:50 AM
JaxEagle's Avatar
JaxEagle
Sounds like the lower mileage that doesn't need a top...
Old Jan 10, 2013 | 09:02 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I have a 1998 and it is great, not a vert though!
You will want to go with the one that has the least to do to it and the most amenities!
Test drive both and then make the decision. You will be surprised after a test drive!
Thanks,Matt
Old Jan 10, 2013 | 09:30 AM
Phanni's Avatar
Phanni
Buy the lower mileage car. The two cars use virtually the same technology.
Major updates took pace in 2001. The 98 may have the EBCM mounted in the rear instead of the front, but they even use the same unit, just in a different position.
Old Jan 10, 2013 | 09:50 AM
Fcar 98's Avatar
Fcar 98
I would go with the lower miles in this case.
Old Jan 10, 2013 | 11:09 AM
johnson-rod's Avatar
johnson-rod
Whichever one floats your boat. Lower mileage is good, year newer wouldn't hurt resale.
I've had a 98 for the last 5 years and took her from 20K to 120K miles. Very reliable.
98 is the first year for convertible - might mean something to someone. Might mean something else to someone else.
Old Jan 10, 2013 | 11:48 AM
JaxEagle's Avatar
JaxEagle
Difference between a 98 and 99 in resale is nil.... imo...
Old Jan 10, 2013 | 12:09 PM
lwise4's Avatar
lwise4
Default Lower miles
Most assuridly LOWER MILES
Old Jan 10, 2013 | 12:19 PM
MrGary2011's Avatar
MrGary2011
Does the 99 have the HUD display? I believe it came out in 99 and is a great upgrade. That being said, I have a 98 and have little repairs done to it even thogh it had 120K on it (mostly dealer miles). I reversed engineered and installed the HUD and LS6 intake which are rather easy and fun to do.
So as the guys said, check each out and go with the one in best condition (I really wouldn't worry about the mileage between the two).
I do love my HUD display though!
Old Jan 10, 2013 | 12:46 PM
Bailout13500's Avatar
Bailout13500
the rear window is a common problem but requires a couple of days to repair. many have done it and posted detailed ifo on how to diy however i went with a local windo shop that has a lifetime warranty in case it happens again.
I bought my 99 vert with 71k miles on it 11 months ago and she now has over 110k. If the difference comes down to a HUD i can tell you when i drive my wifes cars i feel lost wihtout it. It is by far a feature that is a must in any vehicle i buy in the future
Old Jan 10, 2013 | 12:48 PM
Baldfart's Avatar
Baldfart
I would probably go for the lower miles one. Those rear windows in the converts are a piece of cake to fix though.
Old Jan 10, 2013 | 01:21 PM
mxz800's Avatar
mxz800
I would buy the car with the lower miles after I drove both. The window is a common problem so chances are the other car will have the same issue. The window is so easy to fix I even did it.
Old Jan 10, 2013 | 01:46 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I'm a 99 fan. Check all options and compare. The mileage on that one is nothing.
Old Jan 10, 2013 | 04:01 PM
What options are on each car? I had a '99 and it was a very nice car. The rear window repair can be done relatively cheap - there have been posts on how to fix it yourself here on the forum and I have a copy of the procedure.
If the '99 has more options, I would go with it.
Old Jan 10, 2013 | 04:51 PM
Leo23's Avatar
Leo23
Lower mileage is nice, but I think options are at least equally important. Does either have Z51 suspension, as I would consider this a big plus.
Drive them both, and one of them is going to feel "right".
Old Jan 10, 2013 | 05:31 PM
moserbe's Avatar
moserbe
Test drive both, compare options and condition, number of owners, etc.
Old Jan 10, 2013 | 08:00 PM
littlefranks's Avatar
littlefranks
i bought a 99 ,hud,i love it.i bout mine with 127 on the clock ,blew trans and replaced the motor,just cuz i had one.but i work on vettes everyday.plus i hurd tuning is different with the 98 pcm.dont know what but i was just told that.
To Choice between 98 or 99
