Exhaust System Advice
I bought a 2004 convertible a few weeks ago. It had a very loud aftermarket exhaust, but everything else about it was exactly what I was looking for, so I bought it knowing I would most likely want to change the exhaust system.
It has a Magnaflow 15763 exhaust system. A picture of the exhaust system is located here:
http://www.magnaflow.com/02product/d...rtnumber=15763
It sounds great under heavy throttle above 2500 rpm, but it is just too loud and drones too much for me under all other operating conditions. Loud at idle, loud driving around town, etc. Drone at idle, drone at city speeds, drone on the highway. Plus, I don’t like the dual outlets on the exhaust. I like the looks of quad outlets. Time to change out the exhaust so it is ready to go when the weather warms up.
I am considering changing back to a stock exhaust or to a quieter, touring type of aftermarket exhaust.
QUESTIONS REGARDING CHANGING TO A STOCK EXHAUST
If I go with a stock exhaust, the muffler shop will need to weld up new pipes and flanges onto the catalytic converters to reach back to the flanges on the stock exhaust. Should I keep the X pipe and have it welded in these new pipes in roughly the same location as the stock H crossover? Or should I have a stock H crossover put in? I am thinking I should go with the X pipe.
I am currently only considering a base exhaust over concerns that I will have difficulty finding a muffler shop that can competently weld titanium on a Z06 exhaust. However, if flanges are installed, it could probably just bolt up with no welding. Any thoughts on this would be appreciated.
Some websites I have looked at seem to indicate different part numbers for exhausts from different years. Are all base C5 exhausts the same, or do I need to only look at ’02-’04 stock exhausts? The local muffler shop I intend to use has a stock, used exhaust, but I want to make sure it is not from an incompatible year.
QUESTIONS REGARDING CHANGING TO AN AFTERMARKET EXHAUST
I think something like a Corsa Touring exhaust is about what I am looking for in terms of sound level. I understand it is no longer being made. Assuming I can find one used, or still in stock at a vendor, I have the same questions regarding the X pipe.
Thanks in advance.
Sent U a PM on further info.
Thanks in advance.
http://www.bbexhaust.com/car/corvette/c5/
I went with Corsa Touring. Love it.
Correct it is not being made any longer but they are still out there new in box. Got my best price for the Touring model, axle back for 1224.99 delivered from an auction site. He still has 9 more sets as of today.
You could try getting just an axle back system that has mufflers and it would quiet it down. I have no idea how it would sound, but its a cheap solution. Heck you could even put the axle back part of a stock system, and you'd have a very quiet system, and still retain the X-pipe.
I recently put on Corsa Pace Car and absolutely love it. I left the h-pipe, and it does "burble" a little bit, but I love the sound. It sounds fabulous at idle, and when you get going, there is absolutely no drone. I'm sold on this exhaust.
Now, i am running the LG Super Pro headers, X pipe... NO cats with the G5XX cam... Perhaps that is what makes it scream...
Ditch the Magnaflow... those are for trucks! Get yourself the Corsa,GHL... That is my .02 FWIW...
Mine's stock and I'm keeping it. My last one had Flowmaster 50s and I just want a nice growl this time. Not really worried about gaining more power so I think I go with it as designed.
