[Z06] Hurst Short Shifter - Which springs are you using.
Old Jun 12, 2002 | 11:06 PM
Rachel's Avatar
Rachel
Default Hurst Short Shifter - Which springs are you using.
Hurst Short Shifter - Which springs are you using. I am getting one from xtreme this week. Just wanted to know any helpfull suggestions. I am going to install it all by myself in my "Z".
What springs are you using. I was told to use the mediums.
thanks
Rachel
Old Jun 12, 2002 | 11:08 PM
ZO6SPEED's Avatar
ZO6SPEED
Default Re: Hurst Short Shifter - Which springs are you using. (Rachel)
I left the stock ones in. They won't be in much longer... The medium ones are next...
Old Jun 13, 2002 | 01:02 AM
Racer's Avatar
Cruise-In III Veteran
St. Jude Donor '11
Default Re: Hurst Short Shifter - Which springs are you using. (ZO6SPEED)
I love mine the way it came in the box. I love the feel, it is just right. :cheers:
Old Jun 13, 2002 | 10:21 AM
Blue Demon's Avatar
Blue Demon
From: And then it was said... "let there be blue Corvettes and yellow Camaros" Ft Worth Texas
Cruise-In IV Veteran
St. Jude Donor '09
On both our cars I swapped out the stiffer inner springs with the softer ones. I left the stiffer ones in at first to get first hand knowledge of how they felt. After a week I did the swap, very pleased with the results.
Roy
Old Jun 13, 2002 | 10:23 AM
Rachel's Avatar
Rachel
Default Re: Hurst Short Shifter - Which springs are you using. (cruiz)
Did you have to remove the complete console again to change the springs?
Rachel
Old Jun 13, 2002 | 01:11 PM
kh24's Avatar
kh24
I left them stock. At first it was a little hard to shift but after 2 or 3 days you get used to it and i think that if you changed to the softer ones all around it would be too easy and maybe a little limp. I dont think i will go heavier but i may try it when i got nothing else to do. Leave it stock first and then go from there. :cheers:
Old Jun 13, 2002 | 04:46 PM
Blue Demon's Avatar
Blue Demon
St. Jude Donor '09
No, you do not to remove the console again, just remove the shifter **** and then pop the boot off and you can access the hex screws to change out or adjust the springs.
Roy
Old Jun 13, 2002 | 05:10 PM
Rachel's Avatar
Rachel
Thanks Roy
Does the boot come off easy?
Rachel
Old Jun 13, 2002 | 05:24 PM
GaryZ06's Avatar
GaryZ06
Factory setup :cheers:
Old Jun 13, 2002 | 05:55 PM
Fast Mover's Avatar
Fast Mover
Default Re: Hurst Short Shifter - Which springs are you using. (GaryZ06)
Me too, They will soften up over time. :)
Old Jun 13, 2002 | 06:02 PM
Hutch's Avatar
Hutch
Timely info! I'm installing mine next week. Guess I'll go with the medium Hurst springs to begin with. Can always go softer or stiffer later on. And yes, I'm talking about the SHIFTER here! :lol: :lol: :lol:
Old Jun 14, 2002 | 09:37 PM
Rachel's Avatar
Rachel
Default Re: Hurst Short Shifter - Which springs are you using. (Hutch)
Got my hurst in today. All factory...stiff and hard. I hope it softens a bit.
Anyway...I have a guy that makes custom rubber car parts. He made me today a hard rubber insert that fits precisely as the factory one. It is snug inside the closeout boot. Just like factory...
AS QUIET AS FACTORY TOO. No vibration too.
I took a ride with and without....QUIET AND SMOOTH. I may sell them.
Rachel
Old Jun 14, 2002 | 10:47 PM
PeteyPete's Avatar
PeteyPete
I went w/ the stock springs, and have noticed them softening up a bit since the install (thanx kh24), if your not in the mood for exercise, i'd use the softer springs, but i'm pretty content with the setup i'm rolling with now.
Old Jun 15, 2002 | 11:58 PM
Rachel's Avatar
Rachel
Anyone know if you use 2 spings on each side. I think you do.
Rachel :smash:
Old Jun 16, 2002 | 08:03 AM
Hirohawa's Avatar
Hirohawa
I am using the two stock inner springs with the softer outer springs.
Let me know if you decide to manufacture and sell the hard rubber insert. Just installed my Hurst today and it is pretty noisy especially in third.
To Hurst Short Shifter - Which springs are you using.
