tpms
Old Jan 22, 2013 | 10:27 AM
black match box's Avatar
black match box
Default tpms
Does anyone know if you repair your tpms with new batteries, is there any chance that you can reprogram them before you put the tire back on. to see if they actually work. and has anyone done this procedure. THANKS GINO
Old Jan 22, 2013 | 10:40 AM
K-Spaz's Avatar
K-Spaz
From: Central PA. - - My AR15 identifies as a muzzleloader
I believe in the Beer Fairy
Yep, use a magnet and check them all before even closing them up with the silicone. You can do it right from the drivers seat.
Old Jan 22, 2013 | 02:05 PM
Yes, you can check them before installing on the wheels. I checked a set I bought off a forum member before I installed them on the car and they programmed just fine.
To tpms
