[Z06] HELP!!! Engine build question.
Old Jan 29, 2013 | 02:35 AM
sethtyler450's Avatar
sethtyler450
Default HELP!!! Engine build question.
I've got a "new" 418. My question is the built was done in late 2008 early 2009. So the bearing have been clamped down since. Would you guy go ahead and replace the rod bearing and main bearing? I'm not sure if they could be flat spotted after sitting.
Old Jan 29, 2013 | 02:55 PM
Z06FEVER's Avatar
Z06FEVER
I highly doubt that you will run into issues. Some of GM's crate engines sit for long periods of time on the shelf and they work fine. The bearings are being clamped down around a circumference so there would be no room for anything to happen to the bearings. Good luck with the engine!
Old Jan 29, 2013 | 05:03 PM
sethtyler450
Thanks man, looks like lube will be my direction.
Old Jan 29, 2013 | 08:21 PM
Z06FEVER's Avatar
Z06FEVER
No problem, good luck with the car!
To HELP!!! Engine build question.
