Catch Can Owners - How Often Do You Empty?
Old Jan 30, 2013 | 10:11 AM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
Default Catch Can Owners - How Often Do You Empty?
Per the the title, I installed a chrome catch can last year. My C5 is a weekend driver so I'm curious how often do you drain the catch can and at what levels within the can?
Any easy draining tips?
Thanks!
Old Jan 30, 2013 | 10:36 AM
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
Usually not not to often, but that depends of a couple thing, like how hard you drive and your engine. I pull it off at least every oil change. But you might want to check it every so often to see how much is in your can, that way you'll get an idea how much oil goes into and how long it takes to get it there.
I think the fullest Ive seen mine is like about 2/3 full.
Nothin' to dump it, unscrew it and put it in yor used oil. Just remember to put alittle oil on the threads when reinstalling.
Old Jan 30, 2013 | 10:40 AM
MSG C5's Avatar
MSG C5
Thanks. Although my C5 is a weekend driver, I do enjoy "spririted" drives so it gets its exercise!
Since I only change my oil once/year based on the low mileage (I'm at 85% over 10 months), I will check it soon. Based on the design (CCA catch can), I should be able to drain it from the bottom without removing the can.
Old Jan 30, 2013 | 01:05 PM
66BBDriver's Avatar
66BBDriver
Wounded Warrior Escort '11
St. Jude Donor '05
I check twice a oil fill, at change and at 50%. If you track the car, you will need to drain it then.
Old Jan 30, 2013 | 01:31 PM
robert miller's Avatar
robert miller
Thanks!
Nice clean stock looking motor here. Not much I would say for you. Maybe ever oil chg just to see what is going on in it also. But you should be good for a year. If you dont track the car or run it really hard.. Robert
Old Jan 30, 2013 | 01:34 PM
MSG C5's Avatar
MSG C5
Thanks. Pretty much stock with a Callaway Honker CAI, Corsa Indy exchaust w/x-pipe and a C.O.W. A4 tune.
It's not a track car, just a really fun convertible Corvette!
I'm saving my track days for the C7Z stable mate in a few years!
Old Jan 30, 2013 | 05:58 PM
I do not put a lot of miles on my car each year, but I will check the level in the catch can about every 500-1000 miles, which equates for maybe 3-4 times a year. Usually not a lot of oil in there, but whatever amount it's nice to know it isn't going into the intake.
Old Jan 31, 2013 | 12:58 AM
IRON MAIDEN's Avatar
IRON MAIDEN
Every oil change. That simple.
Old Jan 31, 2013 | 11:27 AM
waddisme's Avatar
waddisme
For dd, I never check mine. But I track about once a month, so before track day, and after every 2 sessions. Rarely gets about 1/2 full.
Old Jan 31, 2013 | 12:14 PM
Kap142's Avatar
Kap142
Ditto.
Old Jan 31, 2013 | 12:41 PM
IRON MAIDEN
Originally Posted by Kap142
Ditto.
I have the Elite Engineering can. It has the petcock valve on the bottom to drain but it's just as easy to remove it to drain and clean. I've never had the can more than 1/8th full in a cycle between oil changes. I would say it's less than 1/4 cup of oil. As my oil is draining I pull it, drain it, clean inside and out and slap it back in. Simple task.
Old Jan 31, 2013 | 03:15 PM
Dave68's Avatar
Dave68
While I could wait until I change the oil, I typically empty my glass reservoir twice per year. Obviously, there is no need to "check" by removing anything.
Old Jan 31, 2013 | 03:44 PM
MSG C5's Avatar
MSG C5
That's pretty cool!
Old Jan 31, 2013 | 04:08 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
I have the Mike Norris model and I drain at each oil change.
I have found a really easy way to drain the oil out of
the canister. I just suck it out with a turkey baster. My
canister is harder to drain so I thought this procedure
would work just fine.
Old Jan 31, 2013 | 08:48 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
to get a feel for your situation, I would check it every 3 or 4 month to see what accumulation you might have. If you find you don't have much, at least with each oil change. My 04 is also a weekend or less drive, so I find I only need to dump whatever accumulation there is at oil change time (once a year).
Old Jan 31, 2013 | 09:22 PM
NukeC5's Avatar
NukeC5
I use a clear catch can too, makes it easy to know when to empty it
Old Jan 31, 2013 | 10:10 PM
Mickeyrx70's Avatar
Mickeyrx70
I empty mine with yearly oil changes which means about 3000 - 4000 miles or so. The catch can was maybe 1/4 full.
To Catch Can Owners - How Often Do You Empty?
Old Feb 1, 2013 | 09:38 AM
fishbust's Avatar
fishbust
I bought one with a clear bowl from corvettemods so I can see what is going on, no need to guess.
Old Feb 1, 2013 | 10:07 AM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Thanks!
Looks Fantastic
Typically we see 2-3 oz per oil change on a street driven Corvette.
You can see up to 2-3 oz per session on a track driven Corvette
CCA Oil Catch Cans
Peace
Chip
__________________
..................Click for
Old Feb 1, 2013 | 10:45 AM
MSG C5's Avatar
MSG C5
Originally Posted by CCA Corvette Parts
Looks Fantastic
CCA Oil Catch Cans
Peace
Chip
Thanks Chip! Can I drain the can by opening the Petcock valve and letting the oil run out through the bottom of the can?
