St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
Yeah no C6's had pop-ups.
Sometimes they will pop-up when you use your fogs (or parking lights) if the gear is going bad. They can even do this if you have an aftermarket HID kit installed.
The C5 pop-ups have a standard feature that allows you to clean and service the lenses. Turn you headlights on - they pop up. THEN twist the column switch back one notch and they turn off but stay up.
From: All that glitters is Gold - Hockey Is CANADA'S game
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '05-'06
when i drive with around with my driving lights on and go through a tunnel the headlight will pop up and turn on because of the twilight sensor. then once I am out of the tunnel the headlight turn off but stay up.
Also, people who drive their C5's in a very cold climate will temporarily disable the motors and have them up all the time. This will prevent damage in situations of ice buildup or snow. In the 80's, I had an Acura Integra and it was equipped with a winter switch which would keep the popups up all the time in the winter.
my 2000 drivers side headlight is making a horrendous noise when activated up or down. i pulled it and activated it unhooked. it runs flawless for 6 seconds while the other side only takes about 2 seconds. Does anyone have any suggestions on this problem?
how are the headlight motors replaced. i was able get it unhooked but there was almost no room to get to the three bolts. is the headlight supposed to be disassembled prior to taking the motor out?
The plastic gear is history, buy a kit,, replace gear,,, enjoy life from now on./
Hope that helps.
rr
Road Runner...steal my Avatar...we got to get the Silver Eagles to represent...
Take the headlight out first. It makes things very easy.
