damage from lowering
Old Feb 9, 2013 | 04:41 AM
linz5's Avatar
linz5
Default damage from lowering
just curious. . . .most post address lowering the c5 as a positive. Has anyone had a bad experience with a lowered car? I found my oil filter nearly punctured from a rub i could not avoid. (yes previous owner did the bolt drop). As stated, just curious of other bad experiences. . . .
Old Feb 9, 2013 | 08:14 AM
DevilDog II's Avatar
DevilDog II
Veteran: Marine Corps
Oldtimer
My car is pretty low and I occasionally scrape, but I've never damaged anything. That must have been one heck of a rub to nearly puncture your oil filter. Sounds more like you may have run over some type of debris in the road.
Old Feb 9, 2013 | 09:41 AM
Mr.Bill's Avatar
Mr.Bill
From: Reno is so close to Hell you can see Sparks , State Of Confusion
St. Jude Donor '12-'13-'14
I bet you had a K&N oil filter on your car?
Mine has been lowered for 4 plus years now and one has to watch the speed bumps, Take them slow, I installed Elite Engineering rocker savers and thay have saved me.
Mr.Bill
The K&N filter has a nut on the bottom that extends the filter below the pan and makes it a target for issues.
Old Feb 9, 2013 | 10:07 AM
meflyfrc's Avatar
meflyfrc
Same here, I agree.
Old Feb 9, 2013 | 10:37 AM
glorysends's Avatar
glorysends
I'm lowered on stock bolts with half the bushings cut in the front and lowered all the way in the rear and the only thing that ever scrapes is my middle air dam. As you can see in this picture of how low it is on level ground.
Old Feb 9, 2013 | 11:02 AM
slvr bulit's Avatar
slvr bulit
Dude,that looks awesome.
Old Feb 9, 2013 | 11:05 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
Speed bumps - you will just want to be a little more cautious!
Thanks,Matt
Old Feb 9, 2013 | 12:04 PM
renegad44's Avatar
renegad44
From: This is not a Song, It's an Outburst: Or, The Establishment Blues; Sixto Diaz Rodriguez
Lowered max on stock bolts, a little scraping here and there, but no significant damage to anything.
Old Feb 9, 2013 | 12:38 PM
$$$frumnuttin''s Avatar
$$$frumnuttin'
From: Should this thoughtful, valuable contribution meet with no acknowledgement or 'thanks' this post----
I (and my neighbors...) didn't like the front air dam scrapes entering my driveway...I removed all 3 pieces....the car looks better to me, and no heating issues at all.
Old Feb 9, 2013 | 01:07 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
FWIW, the Mobil1 filter is a little longer than the corresponding AC Delco filter, so you need to be a little careful when using one of those, too.
Old Feb 9, 2013 | 02:46 PM
jrose7004's Avatar
jrose7004
No real damage to speak of on mine, you just have to be careful and pay attention.
_zebra's Avatar
_zebra
my rear is leveled on stock bolts, but then my tires went from standard to Z06 sizes (which are 1/2" shorter), and on top of that, Nittos run a little smaller than standard sizing, so my car will rub occasionally. i drive around speed bumps & any significant dips in the road. other than that, it's been fine - except loading on the trailer is more of a pain in the butt
Old Feb 9, 2013 | 02:58 PM
bladex10's Avatar
bladex10
You just gotta be careful around dips and bumps. I've seen a guy recently that drove his corvette into a slopped entrance head on, the crunching noise made me cringe.
Old Feb 9, 2013 | 04:45 PM
road pilot's Avatar
road pilot
2016 C5 of Year Finalist
Another option--instead of removing the air dam ,just cut it down.
I trimmed mine 3/4 of a inch and I have alot less scraping.
Old Feb 9, 2013 | 05:05 PM
Mr.Bill's Avatar
Mr.Bill
Just do what I did, I just let is scrape and now it is half inch shorter.
Old Feb 9, 2013 | 05:09 PM
Mr. Jean's Avatar
Mr. Jean
Nope, no tools required.
Old Feb 9, 2013 | 05:17 PM
_zebra's Avatar
_zebra
or effort, for that matter
To damage from lowering
Old Feb 9, 2013 | 05:52 PM
linz5's Avatar
linz5
to be fair, we were on a paved country back road (wife driving...still learning the cars character) and dodged one pothole but caught its evil neighbor. The slow speed involved was helpful, but still contact was made. Guess i should have been in the jeep...lol. Anyway, at speed on highways i haven't made sparks fly.... yet.....we are new to the car and man is it awesome(!) but just concerned a little about the underside of the car and its survival rate with it dropped. Thanks for the replies...( ps.....it is a 99 coupe with 64k....shocks are on the "replace soon" list!)
Old Feb 9, 2013 | 06:19 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
If your not scraping anything, your just not low enough
Old Feb 9, 2013 | 06:28 PM
sonny557's Avatar
sonny557
Default 2x4
Going home from work a 2x4 about 6 feet long fell off of a construction truck about the time i was passing, luckily i was able to straddle it, but it bent the frame that holds the middle air dam, just slight damage that I was able to straighten out. I approach and depart my driveway with slight scraping. Otherwise go slow or avoid speed bumps and armadillos !!
