Corvette Creationz
Old Feb 9, 2013 | 11:52 PM
jmac2354's Avatar
jmac2354
Default Corvette Creationz
Just looking for reviews, and or pics from anyone who has or have seen their products. I am looking at getting zr front bumper and zr carbon fiber raised cowl hood. Chime in at will.
Old Feb 10, 2013 | 01:58 AM
vetfeva2's Avatar
vetfeva2
Quick Z06 (Pete) is the forum member that sells the Corvette Creationz items. He is a stand-up guy that sells MANY things to forum members. I have the carbon fiber side skirts and the front diffuser. The quality is amazing. Not the thin lightweight stuff that is out there. Very strong pieces. You absolutely cannot go wrong getting pieces through Pete. I am sure that others will chime in as well.
Old Feb 10, 2013 | 02:07 AM
James2002z06's Avatar
James2002z06
Old Feb 10, 2013 | 02:13 AM
skydiven4fun's Avatar
skydiven4fun
St. Jude Donor '13-'14-'15
I've had nothing but top notch service from Pete as well, his products are top notch and are priced right, I'm running several of his items and all of them fit perfect, no issues at all.
Old Feb 10, 2013 | 01:30 PM
David Shiel's Avatar
David Shiel
Default That is one very nice
looking red C5 you have. I know some don't like the caliper covers, but they look great on yours. I ordered a set rather than paint, as I want to be able to take mine back to stock without any hassle.
Old Feb 10, 2013 | 01:33 PM
vetfeva2's Avatar
vetfeva2
No sir, not covers. These are actual C6Z06 brakes front and back.
Old Feb 10, 2013 | 01:39 PM
MSG C5's Avatar
MSG C5
2018 C5 of Year Finalist
How much drilling is required for the front splitter and side skirts?
Old Feb 10, 2013 | 01:47 PM
James2002z06
Ill take this one , the way the front splitter of mine is designed you have very little room to work with as far as drilling , I went and bought 1/4 by 1 inch long nuts and bolts and just pre drilled holes around the edge of the splitter then used some sticks to prop it up then pre drilled the bottom of my bumper then installed
The side skirts I used a pop rivet gun
Old Feb 10, 2013 | 01:48 PM
vetfeva2's Avatar
vetfeva2
with James
It depends on how obsessive you are as there are no pilot holes on the pieces. I used a combination of existing screw holes and some new holes that I had to drill. The sides have 4 each evenly spaced and the front had 5 new holes (one center, two corners and 2 ends).
I will tell you that I tried the minimal hole approach and the front started to show signs of separating (from my fascia) due to the amount of head wind it gets. That got reworked quickly.
I did it by myself no extra hands, but did need to use various items to balance the pieces on while I worked one end.
Old Feb 10, 2013 | 01:52 PM
James2002z06
Default Hers a few of mine...
Old Feb 10, 2013 | 02:02 PM
David Shiel
Default Side view shows that.
I see that now. Sorry. Did not mean to offend. Car really does look great.
Old Feb 10, 2013 | 02:03 PM
vetfeva2's Avatar
vetfeva2
no offense taken.
Old Feb 10, 2013 | 06:31 PM
jmac2354's Avatar
jmac2354
My Z is torch red as well, some really nice rides I will be doing the zr front bumper and hood with carbon front splitter as well, judging by the pics I think it will look great. Thanks for chiming in guys.
Old Feb 10, 2013 | 06:56 PM
02z06dave's Avatar
02z06dave
I bought there zr hood and the c5r splitter (a couple times). They are good looking cheap pieces. Having also bought carbon pieces from apsis I can say there is definitly a huge difference in quality between the cheap corvette creations stuff and the pricier stuff from apsis. The first hood I received was very misshaped and I ended up getting a replacement. Pete was very easy to work with in that process and provided good customer service. Both hoods also had areas where the carbon weave was a little off and it wasnt very strong. I had the hood on my car for only a couple months and was always very gentle with it and it cracked where the latches are in just a couple weeks. I read at least one other thread where that happened. Perhaps that wouldnt happen if it was painted but I never got around to painting it. About the splitter. These are very thin and crack easily if you bump into anything. I learned that the hard way twice. I have bumped my apsis one only once and it was fine because it has a much thicker fiberglass bottom. Of course, if you arent dumb and careless like me, then you dont have to worry about that. I ended up switching to the apsis after my 3rd c5r splitter broke on a high speed run I did. The air pressure pushing down on it caused the bolts I had holding it on to pull right through the thin carbon fiber and it hit the ground and shattered. Each c5r splitter I had also had areas where the carbon weave was off and one side was thicker than the other by a good half inch.
Having said all that, if you curb your expectations and realize that you are buying cheap carbon pieces then you wont be disappointed. They really are nice for what they are. Pete is also a pleasure to deal with and will take good care of you. Even though none of the things I have bought from him in the past have worked out for me long term, I would buy from him again and I actually plan on probably getting his flared quarters if I cant get tpe and im also thinking about the new hood hes been working on. I believe ive also read that he uses a new manufacturer now that is better, so all the issues I had may be resolved.
This review isnt meant to bad mouth pete or his products because he is a stand up guy who sells a nice product, but in my experience they arent as high of quality as some of the more expensive stuff out there.
Old Feb 11, 2013 | 12:23 PM
CCA Corvette Parts's Avatar
CCA Corvette Parts
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
Originally Posted by James2002z06
Nice Ride
Peace
Chip
__________________
..................Click for
Old Feb 11, 2013 | 08:15 PM
jmac2354's Avatar
jmac2354
So I am a little concerned about the items I purchased mainly the carbon fiber hood, does anyone else have one of these.
Old Feb 11, 2013 | 09:27 PM
James2002z06
What are your concerns ..
To Corvette Creationz
Old Feb 11, 2013 | 10:13 PM
jmac2354's Avatar
jmac2354
02davez06 comments above I did not think I was purchasing some cheap knockoffs hopefully that's not the case and all parts are made well.
Old Feb 11, 2013 | 11:12 PM
Quik Z06's Avatar
0Quik Z06
Former Vendor
Jason,
Here is a customer of mine who has my hood.
http://forums.corvetteforum.com/c5-g...-new-pics.html
What Dave meant was you're not getting an $1800 hood for $650. There can't be that expectation, but for the price, they are really nice. A lot of guys on the forum have this hood. I think you'll be happy with it.
Ps, ill send you tracking in a bit.
Old Feb 12, 2013 | 12:07 AM
TaylorMade's Avatar
TaylorMade
For the money Pete's carbon fiber hoods are tough to beat. My fitment was not the greatest but as others have already stated, you can't expect $2000 quality out of a $650 piece.
