MY 99 not cooling correctly
Old Feb 11, 2013 | 02:46 PM
vettebob2's Avatar
vettebob2
Default MY 99 not cooling correctly
Hello,
I have a 1999 C5 with the original compressor. I have inquired on this forum previously about problems I was/have been having. Admittedly there is a 'small' leak somewhere on/in the compressor. But........
I have had the 'coolant' brought up to correct spec's. We have put on the gauges and have rev'd the engine to proper rpm's and all pressures read correctly to spec's. But.....the A/C will be warm on the driver's side and cooler on the passenger side. We have done the reset where you pull the fuse, wait and the vehicle seems to cool for a short while?maybe it's my imagination? But then the A/C goes back (or continues?) to be cool, kinda sorta, on the passenger side and warm on the driver side.
It looks like I am going to have to take the Vette to a A/C place but I am hoping You All can give some points to look for or be aware of when I take it in and not get 'taken' by the tech's.
I look forward to your responses.
Bob Bray
Old Feb 11, 2013 | 03:41 PM
maxx2200's Avatar
maxx2200
If the gauges are reading the correct pressures it sounds like you may have an issue with your blend vlaves. I'm no expert on the subject but your blend valves need to shut off the flow of radiator coolant to the heater coore in order for the a/c to cool effectively. I'm sure someone with more knowledge will comment.
Old Feb 11, 2013 | 04:02 PM
Oldvetter's Avatar
Oldvetter
Do you have manual or dual temperature controls.
If manual, you may be low on freon.
If dual temperature, then you may have to re-index the driver's side actuator. Try this link:
http://vette.tnreeds.com/actuator/actuator.htm
Old Feb 13, 2013 | 01:17 PM
vettebob2's Avatar
vettebob2
thanks for the info and the link for the 'how too'.
thanks
vettebob2
To MY 99 not cooling correctly
